Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-18-2016, 07:04 AM   #1
Ely , Minnesota
Refrigerator Issue
When I turn on my refrigerator the Auto light and the LP light both come on. I hit the button that should allow me to toggle between Auto and LP but both lights remain on. I have the LP source shut off as I want to just use the electric option. I can hear the LP trying to light (I hear a repeated clicking noise) and eventually because the LP source is shut off I get an LP flashing light indicating that I am out of LP. How can I get the Auto function to light up but not the LP function?
Thanks for any advice and input.
Bert
bertheep is offline   Reply With Quote
Old 07-18-2016, 07:13 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Bert,
Sounds like the fridge doesn't have 110 VAC, so it's trying to run on propane. Are you plugged into shore power? If yes, check to make sure the fridge is plugged into it's 110 VAC outlet and that the outlet has power. Might be a tripped breaker.
The Auto function will try to run on electric, but if it doesn't sense 110 VAC, then it will default back to gas.
Chris
Old 07-18-2016, 10:17 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If after you test the receptacle and have 110 volts there and while the frig is unplugged look at the 2 fuses on the control board.
2004 Excursion 4x4
Old 07-18-2016, 11:46 AM   #4
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I thought when you are in the Auto mode and you have AC hooked up that it will automatically default to AC. I also have a couple of questions. First when you mention both lights are you referring to the little dots. If so it has been my experience that they both come on initially. I also had a similar experience the other day with LP flashing. It was looking for the propane which I did not have on at the time. I turned the tanks on and restarted the Refrigerator. The LP letters stopped flashing, however, the refridgerator defaulted to electric (you can tell by the placement of the dot) and the displayed showed the number 60. this is the default number when first turning the AC. Also remember if it is hot as it has been here in MD it will take awhile for that number to start dropping.
I just don't think it is an electrical issue if the refrigerator light turns on inside the door and the display lights up.
urnmor is offline   Reply With Quote
Old 07-19-2016, 11:34 AM   #5
Ely , Minnesota
I did the same thing, I turned on the LP and the LP light stops flashing, but it never defaults to the electric. Both little green dots are still lit up. I can't seem to get if off the LP.
Old 07-19-2016, 01:26 PM   #6
urnmor's Avatar
Berlin , Maryland
I am no electrician so I usually try the old trail and error method. The only thing I can think of is go back to the basics. If you have checked the fuses and they are good and you are not camping I would turn the propane off and see if the freezer maintains temp. If it does you at least know the electrictiy is working for the freezer. If the freezer stays cold you have at least isolated the issue to the refrigerator and/or the switch that works between the electric and gas. Also could it be possible a board or relay is bad. Maybe some one will have other ideas on how to test it.
Refrigerator AC Issue Joe Oertel Refrigerators 2 05-04-2016 07:10 PM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Refrigerator issue RickJacobs13 Refrigerators 5 10-21-2015 09:12 PM
Refrigerator issue.. won't run when switched to LP ? Focusfactor1 General Repair Forum 6 07-25-2013 09:18 AM
1976 Argosy 24' - Dometic Refrigerator issue NAM_FL Refrigerators 1 05-21-2013 10:51 AM
