Old 01-23-2019, 03:30 PM   #1
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
Refrigerator Interior Fan
Has anyone installed a "muffin fan" on the interior of their refrigerator? If so any links on installation, procedures, pros/cons?
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 01-23-2019, 05:45 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Have not done it myself, but have done some research.
Search online for Smart RV Products. There are some videos that show how to get power either at the light or at the power supply at the back of the refrigerator.
Alan
Old 01-23-2019, 06:19 PM   #3
1994 34' Excella
Warren , Manitoba
I have installed the dual fan set up sold on ebay that mounts on the cooling fins of the fridge. It is wired into the hot side of the light switch. Works very good, however one of the fans has stopped working and I will have to replace it. I highly recommend to help cooling in hot weather. Chris
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 01-23-2019, 06:25 PM   #4
2012 Avenue Coach
Corpus Christi , Texas
As a matter of fact, the was a link (below) in todays email AIR Forums Newsletter Issue 77 - January 2019 - Week 3
http://www.doityourselfrv.com/rv-ref...m_medium=email
rowiebowie is offline   Reply With Quote
Old 01-23-2019, 08:37 PM   #5
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I built my own. Not a hard project and allows you to customize all your dimensions. Fan output can also be customized. Made from 2x3 aluminum tube and some end caps.
ID:	332269   Click image for larger version
ID:	332271   Click image for larger version
Dept of “OverKill”
GMFL is online now   Reply With Quote
Old 01-24-2019, 07:14 AM   #6
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I have the "Fridge Fix" fan installed from Smart RV Products. Installation was simple enough that I don't think I bothered to take pictures when I was doing it. Comes with Velcro to stick to the top of the fridge. There are directions for tapping into the fridge light for power, but I just threaded the wire through the back of the fridge (through an existing penetration used for the thermostat), and tied into the 12V there.
I got the model without the LEDs since I don't feel the need to have LEDs on every darn thing in my rig.
It works wonderfully. There is never any frost on the fins, ever. Cooling is nice and even like a household fridge. It's a little spendy for what it is, and you could probably DIY for cheaper, but in the couple of years since I installed it, I feel I've gotten my money's worth. It makes it much easier to keep a reasonable amount of food for two people living full time.
TheGreatleys is offline   Reply With Quote
Old 01-24-2019, 08:38 AM   #7
1971 31' Sovereign
Palm Desert , California
I used the Valterra FridgeCool RV fan. Less than 10 seconds to install and $15.
CaCraig is offline   Reply With Quote
Old 01-24-2019, 08:43 AM   #8
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i built my own using two old slow speed quite muffin fans. They run off the 12 V supply and circulate air MUCH better
very similar to @GMFL except mine just hand off a home made bracket
waninae39 is offline   Reply With Quote
Refrigerator fan switch or fan dugan Lights - Interior & Exterior 4 09-16-2016 03:59 PM
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 12:41 PM
Fan-tastic Fan Installation With Photos Dabler Roof Vents, Skylights & Fans 9 09-09-2007 09:18 PM
Fan-Tastic fan??? definition needed hex Our Community 26 10-10-2002 03:17 PM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 10:40 PM
