Old 04-16-2016, 12:45 PM   #1
1973 25' Tradewind
Beautiful , Oregon
Refrigerator Installation question.
Hi Folks,
I am hoping I could get some opinions on a refrigerator Installation question. It is probably an easy one. I have built the cabinet to meet all specs (except the gap in back which can't be done with the curved wall of AS) to give me a seal from the inside of the trailer.
Can I shim the back edge of the refrigerator without any problems, to provide a little needed leveling?
Thank you
Tony
Tony S is offline   Reply With Quote
Old 04-16-2016, 01:23 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
In short, yes. However, cabinetry 1-O-1, why isn't your cabinet surface level to begin with? Or, is it your belief that once the curve is cut you might be off level a bit? Either way, be sure you have the trailer frame level first before making the adjustment to the refrigerator or cabinet pointing points.
Sirs Gawain & Tristan (Galahad passed)
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 04-16-2016, 02:30 PM   #3
1973 25' Tradewind
Beautiful , Oregon
Thanks SeeMore
Good question. Although I redid the floor with great care one spot that had a slight hump maybe 1/8 to 3/16 ( like a crown in a joist if it was a house) remained. That area is very isolated but the drop happens to be the last foot going into the C channel behind the refer. I replaced the floor with Marine Fir and did a full epoxy coat on it after checking the frame, sanding and grinding off the rust and then painted POR 15 on it. The frame and the floor is sound but that is the way it is. Anyway good question back to me.
Tony
Old 04-16-2016, 02:36 PM   #4
2007 22' International CCD
Just make sure that the fridge is shimmed level when the floor or whatever reference surface you will use to level the trailer is level also. In mine, the counter top above the fridge is my reference when parking so the fridge is more or less level.
rmkrum is online now   Reply With Quote
Old 04-16-2016, 02:46 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Tony, if I understood your reply correctly, I'd consider shimming the cabinet at the floor so all aspects of the cabinet would be level or perpendicular as my first approach.
Old 04-16-2016, 04:26 PM   #6
1973 25' Tradewind
Beautiful , Oregon
The cabinet is level. It is just that the refer prior to shimming fell back a little bit leaving contact ( seal ) with cabinet edge. Shim will tilt up and restore contact. A couple of pics
ID:	260876   Click image for larger version
Old 04-16-2016, 04:56 PM   #7
Be sure to fasten the shims in place when you final the fit, so they don't move and possibly warp the fridge. A slight warp can make the door seal leak a little. Been there...
Old 04-16-2016, 05:30 PM   #8
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
I think one of the most important part of the installation is making sure that the rear of the fridge is separated from the front so the airflow comes in at the lower exterior access door and flows up and out of the upper vent of the Airstream to the rear of fridge.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Refrigerator Installation question. Tony S General Repair Forum 4 04-06-2016 08:22 PM
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 05:34 PM
Snyder Refrigerator Kit Installation Help? vhariable Refrigerators 4 05-09-2013 08:44 AM
3 refrigerator installation questions Lothlorian Refrigerators 16 03-06-2011 10:40 AM
Tips on refrigerator installation? borostreamer Refrigerators 34 04-04-2007 03:24 PM
