Old 07-17-2012, 10:39 PM   #15
rogerdodger's Avatar
Fresno/Clovis , California
Originally Posted by DKB_SATX View Post
This is why I keep beer in an ice chest instead of the fridge (that and the fact that 32F is a nice beer temp!)
I will drink to that!
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 07-18-2012, 03:41 AM   #16
1972 31' Sovereign
1979 29' Ambassador
west monroe , Louisiana
Originally Posted by Jammer View Post
In general the test to run is to put a thermometer in the cold air outlet on the A/C and measure the temperature compared to the ambient indoor temperature. There should be a 20 degree drop. If there is, the air conditioning is working fine and your problems are elsewhere (weatherstripping, insulation).
If not check the cleanliness of the coils.
In general the old units do not leak freon, and if they work at all, work as well as new units.
I'll rmv the cvr and ck the coils, I know the temp diff is nowhere cls to 20deg. It's more like cool air coming from the unit.
Also, the fan is noisy and is always running when turned on (the fan does not stop when (if) temp setting is reached. And, I've noticed that the cooler air is hard pressed to get out of the mid bedroom, esp to the bath area. Thanks.
litlgeezer is offline   Reply With Quote
Old 07-18-2012, 05:20 AM   #17
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
That is good advice with the thermometer at the duct. I believe the fan running all the time is normal too. My ac unit is noisy when running. The compressor kicks in and out but the fan always runs. If you clean your coils and the unit does not cool, it probably does need replaced.
