Hello folks. Just returned from on long weekend in the AS. 2016 FC25. Emptied the fridge and turned off the power button inside the freezer section. Pretty sure it's a model RM3762. The unit appeared to turn off but the fan continued to run. Did not stop until I pushed the "Store" switch by the entrance door that disconnects the battery. Left the door open on the fridge for about an hour to defrost. About an hour later returned and pushed the "use" switch to engage battery power to the trailer. The fridge fan is running again and the LED display on the fridge shows nothing so assuming it is turned off. Hit the "Store" switch again and the fan stops. This has not happened before. In the past, shutting off the fridge stops the fan. Any ideas what's going on?
Thanks!
Dave
