Old 03-01-2015, 05:46 PM   #1
chaseav's Avatar
2015 25' FB International
Refrigerator Doesn't Work! Mayday!
So my wife and I just arrived to our campsite on our very first trip in our brand stinking new Intl Signature 25FB. All is going according to plan EXCEPT the refrigerator will not turn on. Pressing the power button does nothing.
I've checked the fuse; all appears fine and I believe other items on that fuse work. The fridge is plugged in to its receptacle inside the exterior cover. The owners manual doesn't give a troubleshooting item if there is no power.
So, I'm left with two conclusions. I either have a power source problem that I'm not going to be able to resolve "in the field" OR I'm doing something stupid and triggering some sort of fail safe mechanism that is preventing it from starting.
PS- All other electrics appear to be functioning as intended.
PPS- This is also the first trip out of winterization.
Help!
chaseav is offline   Reply With Quote
Old 03-01-2015, 06:00 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Does it work on gas?
MICHAEL
Old 03-01-2015, 06:02 PM   #3
chaseav's Avatar
Negative. No power at all on the display.
Old 03-01-2015, 06:06 PM   #4
2007 22' International CCD
Also needs 12volt power, possibly.
KE4GNK/AE
Old 03-01-2015, 06:10 PM   #5
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Go ouside and look inside the fridge exterior access door. Maybe the installer at the factory did not plug it in. I've done that after reinstalling my fridge after repairs.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 03-01-2015, 06:24 PM   #6
1986 31' Sovereign
Miami , Florida
Any chance you are still in "store" mode? Sounds like the frig isn't getting any 12 volt doc...
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-01-2015, 06:27 PM   #7
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Did it work before? If the plug in the outside compartment tight? The buttons that turn it on are covered with a rubber cover. Sometimes that cover displaces and pushing it does nothing. I think you have to remove the plate over the buttons to readjust it, but sometimes fooling with it gets it back in the proper position. Is there propane in the tanks? If they went empty, it can take a while before gas gets to the fridge—if the stovetop burners work, leave them on for a few minutes to move propane through the lines and push out the air. The fridge will try 3 times to light on gas and then quit. Turn it off at the button and then wait 30 seconds and turn it on—maybe that will work. There are a lot of 12 v. connections in the back of the fridge—pull off one at a time, clean both sides, put it back, move on to the next one, etc. Do not remove more than one at time because you will get them mixed up. It can be difficult to tell if the fuse is ok. Change it out with another fuse of the same amperage to see if the fridge works then. Then go buy extra fuses.
The fridge will take many hours to cool on electricity and less time on gas. It may be working, but not enough to cool yet. Use gas only if you want to cool it faster. If on gas, locate the gas burner at the back and see if it is hot—I don't think it gets too hot so it burns your hand, but you should be able to feel some heat when your fingers are close but not touching. You may be able to hear a flame.
If none of that works, call the dealer and your mother. Your mother probably doesn't know how to fix it, but she will be comforting. Then go out to eat and buy some ice.
Gene
Gene
Old 03-01-2015, 06:28 PM   #8
chaseav's Avatar
Got it! So get this: Having just pulled it out of storage and reconnecting the propane tanks, it appears that the system was in fact in some sort of lock out mode because there was no propane in the line. I realized this might be a problem based on reading the ops manual and so I light the stove and within 2 seconds the fridge kicked on. Unreal. "Smart!"
Thanks for the help all! This forum is incredible.
Old 03-01-2015, 06:36 PM   #9
AWCHIEF's Avatar
Images: 33
Excellent, now get that ice making.
MICHAEL
Old 03-01-2015, 06:48 PM   #10
Espyville , Pennsylvania
I was reading along to see if I could be of assistance and I see that you've found a solution. We've probably all just learned a little here. Good job. That is an awesome fix!
Martin724 is offline   Reply With Quote
Old 03-01-2015, 07:06 PM   #11
chaseav's Avatar
Update: The temp display just reads 60 now. Doesn't appear to be doing anything and unit not making any sounds. It does feel cool in there though. But at least we know it's not a power source problem!
Old 03-01-2015, 07:19 PM   #12
1986 31' Sovereign
Miami , Florida
Going to take awhile. Probably tomorrow morning before you get a stable, useable temperature. Absorption reefers are like that.
Mike
Young, lovely bride
Old 03-01-2015, 07:36 PM   #13
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Put your hand against the back wall of the freezer compartment. If it is working properly, it should feel quite cold.
You can help the refrigerator along by putting a bowl of ice in each compartment.
Brian
SuEllyn & Brian McCabe
Old 03-01-2015, 07:40 PM   #14
chaseav's Avatar
The freezer is getting coldish. The fridge is still room temp, maybe a slight chill. Looks like it's functioning normally but I'm unable to turn it off using the buttons inside the freezer door. Also can't select a temp.
1966 Caravel ....Mayday ....Mayday. Melody Ranch 1966-68 Caravel 18 09-08-2015 03:04 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
My fridge doesn't work on AC... John Greenlee Refrigerators 3 08-08-2004 10:49 AM
Fridge doesn't work on ac jwaldin Refrigerators 5 04-10-2003 10:38 AM
