Originally Posted by Belbein
This is more maintenance than repair, but I need some help with two very disparate things:
1. While cleaning the 'fridge, my wife took the bottom bin out. How in the ever-loving-************ do you get it back in? I'm pretty good with spatial reasoning, but this has defeated me. I can't get the door open enough to get it in.
2. Window screens: Someone who shall go unnamed managed to de-attach a window screen. I can't get it back on. What's the trick?
Ok so you'll throw the wifey under the bus but...
1. Depends on the fridge, ask flattened wifey how she got it out. Try lifting the shelf above it up out of the way at an angle.
2. What do you mean by detached the window screen? You knocked the screen out of the spline? If so you'll want to take the screen frame out so you can lay it flat, pull out the spline near where it got pulled out, use some tweezers to pull the screen under the spline and push the spline back into the groove. You can try with the frame still installed but it's more difficult. It's almost easier to just replace the screen though.
