Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-07-2016, 06:54 PM   #1
Miami , Florida
Reflection Insulation
Hi. We were going to adhere a layer of foil bubble insulation against inside of outer skin. Create a space and then another layer of bubble foil. Read where it says to space it away from inside of outer skin. Read also where they used thin batt between two layers of foil bubble. Help. We are confused. Overall what do you think is best way? Thanks in advance
Dave rem is offline   Reply With Quote
Old 06-07-2016, 09:41 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Might as well ask what kind of hitch you need. There's really no right answer, just a lot of opinions.
I loosely adhered bubble foil to the upper interior most likely to get direct sun using 1/16" foam tape, then spray glued 1.5" batts of rockwool on top. I also insulated the ribs with the same foam tape and some foam sill gasket. Not saying that's the best way, it's just what I chose to do, and it seems to be working pretty well so far.
I didn't think using the bubble foil as your my only insulation was a good idea, but plenty of people here do. It's not really designed for the application, so there's no "right" way to do it. Just be aware that you get no reflective value if it's touching the surface you want to reflect heat from, just a small r-value.
TheGreatleys is offline   Reply With Quote
Old 06-11-2016, 10:02 PM   #3
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
Foil bubble has very little r value (R-1.0). Not much more than the aluminum shell (R-0.63). A waste of time and money in my opinion.
AlbertaBound is offline   Reply With Quote
Old 06-12-2016, 03:56 AM   #4
Images: 59
Dave, if you search on the tradename Reflectix you will find lots of people have used this material. Happy hunting.
Insulation- Prodex or Foam Insulation Board? Danny Z General Interior Topics 7 08-26-2015 08:21 PM
Basecamp at seven months....a reflection DCtraveler Base Camp 13 04-26-2011 05:18 AM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
Reflection.. AUstreamer General Motorhome Topics 4 03-09-2010 07:53 AM
Snowbirds - pause for reflection RangerJay Winter Living 33 01-16-2009 05:46 PM
