Old 04-05-2015, 02:17 PM   #1
mje
2013 30' Flying Cloud
Refer quit working!
My Domestic 8cu ft refer stopped working on the beginning of my last camping trip and I lost most of perishable foods in it. Gas does fire up when turned on but produces no cold air. Not sure where to check - it's about 2.5 years old. Any advices? Thanks!
mje is offline   Reply With Quote
Old 04-05-2015, 02:36 PM   #2
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Does it work on AC and/or do you get any error messages on the display?
Landrum is offline   Reply With Quote
Old 04-05-2015, 02:51 PM   #3
Okiestreamer's Avatar
1999 25' Safari
Adair , Oklahoma
I have an older unit but it requires the trailer to be relatively level to work on LP gas. Make sure your Airstream is level then see if it works.
Dave
Okiestreamer is offline   Reply With Quote
Old 04-05-2015, 05:04 PM   #4
2005 19' Safari
GLENDALE , AZ
The Dometic warranty period is 3 years. If you are unable to easily troubleshoot and correct this problem, do not delay in seeing an authorized Dometic service center.
Old 04-05-2015, 06:32 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
If your LP is burning and heating the boiler section ( the vertical silver tube on the left side of the unit at the rear) and you are not getting any cooling, it sounds like you might have a blockage in your cooling unit which is preventing the proper flow of the heated ammonia thru the cooling unit.
A quick check is to open the outside door at the back of the fridge and place your hand on the horizontal cylinder to see if it's warm. Then feel the lowest coil right above that. They should be about the temperature of the unit is operating normally.
If not, your Dometic warranty should take care of installing a replacement cooling unit.
Old 05-02-2015, 01:52 AM   #6
mje
Update on Refer
I wanted to give you all an update since my post of an issue with my refer. I tried everything short of taking it out and "burp" it. I decided to take it to the local Airstream dealer to take a look at it. It turned out that the cooling unit is broken and was replaced under warranty. Thanks for your help and input here and in PMs.
Refer just quit Working Bfrank Refrigerators 13 07-16-2011 10:32 AM
New Shurflo pump quit working? Lothlorian Water Heaters, Filters & Pumps 9 12-14-2008 06:08 AM
DC quit working in my new 64 Globetrotter GlobeTrottin Batteries, Univolts, Converters & Inverters 11 09-06-2007 08:06 PM
'96 LY fridge quit working airstream96 Land Yacht/Legacy Motorhomes 5 07-02-2007 09:05 PM
The ol' Dometic quit working... InsideOut Refrigerators 5 08-09-2004 05:07 PM
