Old 03-24-2013, 09:40 AM   #1
Hobo
2006 25' Safari
Florence , Oregon
Refer Madness
The sun totally destroyed the water drain tube in the Dometic refergerator of my 05 25' Safari. I had to take the refer out to replace it, which I did but upon reinstallation, I see that there is a small blue wire (about 28ga) with a female connector coming out of the fuse box on the back bottom of the unit that I have no idea where to hook it up. Did I miss a connection or does anyone know what the wire is for? I hate it when I do this?
voremus is offline   Reply With Quote
Old 03-24-2013, 11:01 AM   #2
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
This is not the conversation I thought we were going to have based on the tread title.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 03-24-2013, 11:45 AM   #3
Over59's Avatar
Putnam , Connecticut
Images: 37
Put a meter on it to check if it's a 12V positive with fridge on and then with it off. It may be for an optional fan kit or could be now....
It is not a cooling connection for either AC or DC, too small.
Of course you did not disconnect any wires from the board
Over59 is offline   Reply With Quote
Old 03-24-2013, 03:38 PM   #4
Hobo
2006 25' Safari
Florence , Oregon
Thanks for the input. I checked out the wire and found it to be a "test point." Sorry if I misled anyone with the title.
