Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-22-2019, 01:27 PM   #1
2019 30' Classic
Belleville , Illinois
Rear stabilizer jacks not working
2019 Classic 30.' Front stabilizers work fine. But when I engage either the extend or retract button on the rear stabilizers nothing happens. No movement no click no nuthin'
I can't find a dedicated breaker and the owners manual is no help. Any suggestions?
Thanks.
Presitla99 is offline   Reply With Quote
Old 07-22-2019, 02:35 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I really don't know anything about them, but it would be a fuse and not a breaker (if that was the problem). Did you check the fuses?
2019 Ford Expedition Platinum
Old 07-22-2019, 03:22 PM   #3
PKI
PKI's Avatar
Walnut Creek , California
Call the dealer. Most valuable phone number when you buy a new coach is the service manager's phone number. Next is the JC customer service number.
Battery condition? Front running off TV - rear off battery and they are dead? crazy, but maybe?
As suggested, a fuse.
Can you manually run them down. That may release a bind and get all moving again.
Have you operated them prior? Is this a mfg fault? Are they even connected?
Has anyone suggested yo call the dealer or JC. . Hope you get it figured. Bummer. Pat
Old 07-22-2019, 03:34 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Mine have a fuse on the jack control panel. There is also a circuit breaker for the jacks.
Al
Old 07-23-2019, 11:36 AM   #5
2000 30' Excella
Sarasota , Florida
My 95. 34’ had an an in-line fuse at the stabilizer location. 30A buss fuse that wasn’t easily sourced. But I didn’t try eBay either.
GatorDave is offline   Reply With Quote
Old 07-23-2019, 12:19 PM   #6
Sag Harbor , New York
FYI these search results may lead somewhere productive:
https://www.google.com/search?q=elec...=airforums.com
http://www.airforums.com/forums/f457...rs-178738.html
Bad ground/switch: http://www.airforums.com/forums/f457...rd-181277.html
Manual operation: http://www.airforums.com/forums/f540...ks-182027.html
Good luck,
Peter
FYI/FWIW
Old 07-23-2019, 01:24 PM   #7
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Thanks.
Hi Presitla99,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 07-27-2019, 08:28 AM   #8
2019 30' Classic
Thanks all but no luck.
Cannot locate a fuse. Dealer could not help. Telephone call to Eric at Jackson Center not helpful. No clicking when I try to extend or retract them. I manually raised and lowered several times but still no movement when with depressed. I'll contact the mother ship-again.
If anyone knows where the fuse is located for the rear stabilizer please advise and thanks.
Old 08-02-2019, 08:28 AM   #9
2019 30' Classic
I have the solution and want to share it for future reference if anyone else experiences this issue. The Switch is bad. Below I have copied the response fro AS customer service which led me to my conclusion:
The wires for this stabilizer jack originate at the front end board located at the front of the unit located under the furniture. the wires the travel to breakers located behind the microwave. They then run to the switches for the stabilizer jacks and power is distributed to the jack motors from there. If you have a meter, remove the switch and check the power going into the switch (red or yellow wire depending on which side). If we have power to the switch and the motor is not making any sort of noise at all, it is likely that the switch has gone bad. If we have a technician look into this, they would be able to pinpoint the loss of power.
Old 10-04-2019, 01:59 PM   #10
2019 30' Classic
Follow up: the culprit was a bad motor. All is well md thanks for the advice from all.
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
frozen stabilizer jacks silver suz Jacks, Stabilizers, Lifting and Leveling 10 03-24-2004 10:12 PM
How many stabilizer jacks are standard? Janet H All Argosy Trailers 3 03-13-2004 10:09 PM
