Old 09-27-2008, 10:20 PM   #15
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Christmas Tree Looking Thing
That thing is a water valve--originally part of a kit intended to extend a water faucet to a more convenient location. We were using it as an emergency shut-off while we were testing a newly-installed Pex water system. PO sorta let things freeze. After the flood that resulted when we first hooked water up to this trailer, we opted to have a shutoff nearby for the next test.
Old 09-28-2008, 04:09 AM   #16
Originally Posted by mimiandrews View Post
Here are the photos Andy asked me to post of the area where we found the water leak. Hope I got the right shots.
The leak damage is just inside the lower left (street side) corner of the rear hatch. Replacing the seal around the hatch is the first thing we did, and that didn't stop the leak.
What is the proper sealant for stopping this leak? I've used silicone caulk, but have picked up some stuff on the forums that indicate this might not be correct.
It appears that your Airstream may have rear end separation on the left side. That would let water get to the bottom of the floor.
Silicone sealer is "NEVER" correct for the exterior.
You need to remove it "completely," making that area "chemically clean" so that Par-bond or Vulkem will adhere.
You cannot install any sealer over silicone sealer until you remove "ALL" traces of it, even chemically.
Old 09-29-2008, 11:29 AM   #17
1966 22' Safari
Weatherford , Texas
OK, guess I goofed when I used the silicone. What do I use to remove it down to the "chemically clean" stage I need?
Old 10-13-2008, 08:31 PM   #18
1966 22' Safari
Weatherford , Texas
OK, the silicone didn't stick. What do I use to get it completely removed so that the Vulkem will stay?
At wits end with propane leak. ArtStream LP Gas, Piping, Tanks & Regulators 13 09-27-2015 06:55 AM
2005 Interstate rear bath-water on floor after a rain herrgirdner Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-17-2007 09:17 PM
Rear End Sag JimGolden Repairing/Replacing Floor &/or Frame 7 11-09-2005 09:20 AM
rain leak mvbuster Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 03-19-2003 10:37 AM
rear end leak Daddy4Bob Mechanics Corner - Engines, Transmission & More... 7 02-14-2003 08:22 PM
