Old 05-17-2015, 10:23 AM   #1
Ponyfvr's Avatar
2015 25' International
Scottsdale , Arizona
Rear Bumper repair AS International
I backed into something and hit the end of the bumper and it put a crease in about a foot from the end. How can i fix this? Should i remove the bumper and try to straighten it out with a rubber mallet? Or should i just take it to the dealer.
Thanks for your help
ID:	238608   Click image for larger version
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
Ponyfvr is offline   Reply With Quote
Old 05-17-2015, 11:29 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I did something similar, hung the bumper end on a post in my driveway. A mallet won't do it. A friend and I straightened it with a couple of deformable blocks in a small hydraulic press. The bumper comes off with two screws into the frame on each side. Pull it and take it to a body shop if you don't have access to a small press.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 05-17-2015, 12:53 PM   #3
1979 23' Safari
Wayland , New York
Easy to take off as Al mentioned, a good body shop or metalworking shop should be able to get it straightened out pretty good. If that's not good enough you can buy a new one fairly easily. Easy off easy on.
Old 05-18-2015, 01:09 PM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The bumper is easily detached - I decided in my case to order in a new one and bolt it on.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 05-18-2015, 02:14 PM   #5
Ponyfvr's Avatar
Thanks everyone great ideas. Any idea on the cost of a new bumper and where to order it?
WBCCI # 5462 4CU
Old 05-18-2015, 02:37 PM   #6
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Mine was damaged when I bought the AS. It looked almost twisted as the original owner got something caught underneath and pulled the bottom out. We beat mine to death and it looks pretty good but before that I took it to a body shop and he said he could not fix it if it was removed from the vehicle because it was aluminum. So, that is what led to me trying to fix it. I will post a pic when I find it.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-18-2015, 08:14 PM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I recall the cost being around $250 (including the shipping).
VE3JDZ
AIR 12148
Old 05-19-2015, 06:58 PM   #8
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Same thing for me by the PO. Easy to remove and repair if you are handy with a 3 lb sledge and a hydraulic press. If not, a good mechanic should be able to fix it in less than 30 minutes.
NavyCorpsman is offline   Reply With Quote
Old 05-22-2015, 05:10 PM   #9
Ponyfvr's Avatar
Update: I ended up taking the bumper to a auto body shop and they did a great job getting it straight Cost $100 dropped it off in the morning and picked it up in the afternoon.
Thank you everyone for your help and ideas.
WBCCI # 5462 4CU
Looking for body parts to repair my rear back bumper assembly Mr. D Classic Motorhomes 7 08-30-2014 02:01 PM
Bumper/Frame repair help Skamper1 Bumpers & Bumper Storage 13 08-19-2012 04:58 AM
Rear bumper repair - 2000 classic grumpy Bumpers & Bumper Storage 4 04-03-2012 04:19 AM
"PVC" Styled Sewer Storage/Rear Bumper Storage Repair Frank&Mike Bumpers & Bumper Storage 5 11-04-2010 08:30 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
