Old 04-20-2014, 04:27 PM   #1
Osogofind
1975 25' Tradewind
Re working kitchen drain- pex for drain lines??
I'm replacing / re routing my drain Lines- the current ones are PVC- I'm wondering if I should replace the new segment with pex ( do drain lines ever use PEX??)? It will tie into the other drain lines for the shower going to the holding tank which will remain as PVC.
Bwilson11 is offline   Reply With Quote
Old 04-20-2014, 06:31 PM   #2
asbury park , New Jersey
I have never seen pex used for drain lines. I don't think they make pex in1.5"?
NJtoNC is offline   Reply With Quote
Old 04-20-2014, 06:35 PM   #3
1974 Argosy 20
Kooskia , Idaho
There is no reason to use PEX for a drain line, even if you could locate the proper sizes. ABS and PVC are just fine.
Old 04-20-2014, 07:53 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Unless someone has replumbed your trailer you should have the black ABS. I would go back with the same, make sure you get the correct pipe cement. PVC cement doesn't work with ABS. They make a universal that should work with both.
Aaron
WBCCI #XXXX AIR #2495
Old 04-20-2014, 08:42 PM   #5
CHIEF THINGAMAJIG FIXER
1964 26' Overlander
bugtussel , South Carolina
pex is made in larger sizes typically used in europe for commercial applications. I don't think it is recommended for drain applications only supply side. Wahoo is right , use the black abs for drain applications and make sure to use the correct glue and also abs fittings to put everything together. Lowes or HD should have whatever you need.
Bugtussel is offline   Reply With Quote
To PEX or not To PEX perryg114 Sinks, Showers & Toilets 69 10-04-2012 04:32 PM
Midway through pex.. Any tricks to get lines over to shower under floor? mikeandnora Plumbing - Systems & Fixtures 3 06-15-2012 05:34 AM
Total redo with pex, one drain valve? Northlander Plumbing - Systems & Fixtures 10 11-23-2011 04:09 PM
