Old 05-28-2010, 01:32 PM   #29
2004 28' Safari S/O
Livingston , Louisiana
It has now been over one month since I cleaned out the opossum. I have not any additional troubles with the oppossum or mice. I did put out a lot of moth balls and several of the things that you can hang inside your toilet bowl. I have also put moth balls in my AS storage areas and on the gound under the trailer. I also plan on putting some inside the trailer in all of the holes in the floor. Yes, I know that they do smell but I think that to seal up all openings around the AS will not be good for air circulation to reduce moisture buildup and rust. As for me, I will take a little smell in order to do away with the un-wanted guest and rust/corrosion. After all I do live in SE Louisiana where we have a lot of it all.
david686 is offline   Reply With Quote
Old 05-28-2010, 01:59 PM   #30
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Hi, I saw these gaps in the frame extensions, [out riggers] in front of and behind the wheels. This is in the wheel well area and too large to use the foam sealer on. So I bought two builder's plates, cut them in half, and pop riveted them in place. I saw these when I was doing my other mouse proofing, but I was unable to get to them. I waited until I was ready to do my brake and wheel bearing inspections. It's much easier to reach with the wheels off. I hope I have all bases [mouse holes] covered.
Name:	IMG_2025 (Large).JPG
ID:	103474   Click image for larger version
Name:	IMG_2024 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 12-28-2011, 02:15 PM   #31
ole-red's Avatar
2007 19' International CCD
2002 19' Bambi
2005 30' Classic
Dover , Arkansas
Mud wasp
I read the posting from Norcal regarding the mud wasp....I was told and shown by a friend of mine who I bought my first bambi from, that they don't like yellow paint....He had paint strips about every four feet running up and down his interior walls of his unfinished garage....The vent piping on top of the bambi had been painted with the yellow paint, and he swore by it....He said they wouldn't come near it...Now if that works, a person could put strips on the bottom of the belly pan which couldn't be seen and should keep them from building their mud nests....
ole-red is offline   Reply With Quote
Old 12-28-2011, 06:26 PM   #32
RR , British Columbia
Images: 13
Something like this might work??
Dave
Old 12-29-2011, 05:55 PM   #33
dznf0g's Avatar
Oswego , Illinois
I noticed those obvious critter and water entry points also. I filled with sealer.
"All I want in this life of mine..... is some good clean fun" - Little Feat
Newbie electrical questions -- "Use" and "Store"? jjboone101 Batteries, Univolts, Converters & Inverters 8 08-27-2009 09:44 PM
Meeses (Mice) "Tis the season.. flamingo-kid1 Our Community 20 03-15-2005 08:20 PM
