Rant about construction
I am nearly finished with my project to upgrade to Lithium batteries and will create a separate post for that. This post is my huge disgust at what I discovered about construction during this project. It will be my only rant.
I now have a profound respect for individuals who do these projects.
First, Airstream has incomplete documentation of as-built. OK, for electrical you can trace most of it, but not all. Ideally drawings and schematics would show everything; they do not.
None of the wiring has labels, there are no cable ties or harnesses. They have splices, some of the wiring is undersized for its application, and they do not even stick to their own color code. For example, they spliced a black wire to the green solar negative wire.
Then when they finish this hodge-podge they just cram all of the wires against the wall of the trailer and install a plywood divider so you cannot access or see the wiring. Seriously, all of the wires going to the DC bus, the ground bus, and excess lengths of wire are just pushed together.
I suppose it is the nature of the game that I had to remove all of the bed plywood to gain access to the electrical area.
If I had to work on this stuff for a living I would need serious medication!
I know, a normal owner would never need to access this or know about it, but for the price of an Airstream, I would expect better. Certainly every car and every boat does a much better job.
Rant over,
Larry
