Old 09-16-2018, 10:29 AM   #1
Boerne , Texas
range / stove hood vent
The flap has come off of the stove vent that exhausts air from the range hood. It seems to be some kind of heavy tape and there are two of the flaps. An outer and an inner. The inside one is still intact because it is riveted on as you can see with the blue tape but I'm wondering what can be used on the outer one knowing that it needs to be flexible enough to allow the flap to move open and closed but also durable and not dry out like duct tape would do?
Name:	Airstream stove vent 1.jpg
ID:	322653   Click image for larger version
Name:	Airstream stove vent 2.jpg
Name:	Airstream stove vent 3.jpg
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley.
Tow With: 2006 Dodge 2500 Quad Longbox 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr programmer, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 09-16-2018, 11:09 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
A brand-new outer vent is less than $15, I'd probably simply replace it, rather than improvise something.
Old 09-16-2018, 11:28 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I bought one from ODM. Takes less than half hour to install, an easy DIY project.
http://odmrv.com/catalog/index.php?m...oducts_id=1149
This vent is available in gray/silver, white, or $tainless $teel.
ps:
When I'm in FL, I mail order from ODM. They usually ship the same business day if I order in the morning and I receive 3-4 days later. Shipping normally cost me less than driving to the nearest place I can purchase.
Alan
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 02:41 PM
Stove range hood vent leak frankiannell Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-05-2015 11:11 AM
Leak around range hood vent '74 Tradewinds chuman70 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 05-29-2007 03:54 PM
New Airstream Vent/Range Hood Question kneal 2007 Safari 8 03-23-2007 11:06 PM
Range Hood Vent Cover Chuck Roof Vents, Skylights & Fans 0 08-06-2003 07:31 AM
