Old 03-24-2015, 12:49 PM   #1
1977 31' Sovereign
Lynnwood , Washington
Range hood filter -
1977 Airstream Sovereign 31' -
I need to replace the aluminum grease filter in the range hood; 22" X 12." The expanded aluminum filter material is pretty clogged/shot.
I've tried cleaning it in the past, but with marginal success. I would prefer to replace the material instead.
Some years back, I managed to find some bulk, expanded aluminum filter material in an old-fashioned mom & pop hardware store. But I can't seem to find it any more.
Does anyone have any ideas??
Thank you.
Tom
TomKirk is offline   Reply With Quote
Old 03-25-2015, 08:30 AM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Our furnace at home has an electrostatic filter system which has a pre-filter of this aluminum filter material. Thus, I would suggest contacting an HVAC service contractor to see if he has a panel that you could cut down to fit your needs.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 03-25-2015, 10:15 AM   #3
Zil
egg harbor city , South Jersey
Aluminum? Mine were stainless steel and were cleaned soaking in lye solution. Don't use lye on aluminum or galvanized.
Zil is offline   Reply With Quote
Old 03-25-2015, 10:17 AM   #4
dznf0g's Avatar
Oswego , Illinois
I have found that running them through the dishwasher on "sanitize" cycle (very hot) cleans them very well.
-Rich-
Old 03-25-2015, 12:09 PM   #5
1977 31' Sovereign
I'll try the HVAC route. Thank you for the good advice.
Tom
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Less expensive alternative to hood vent filter nick_gee Stoves, Ovens & Microwaves 11 01-05-2016 05:30 PM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 12:49 PM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 06:08 AM
Range Hood Vent Cover Chuck Roof Vents, Skylights & Fans 0 08-06-2003 06:31 AM
