Old 06-21-2014, 04:25 PM   #1
1970 31' Sovereign
Gastonia , North Carolina
Ran into my first dilema...
So I'm taking all the trim, banana wraps, and side wraps off when I noticed something odd. Street side wrap is sandwiched between the side panel and the C-channel on the floor. The curb side isn't a separate piece at all. It's just a continuation of the side panel wrapping down and under. Actually, that's easier to deal with as far as less rivets to drill out, but will now get in the way when I lift the shell.
drchris66 is offline   Reply With Quote
Old 06-21-2014, 04:35 PM   #2
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Chris,
I'm not familiar with the construction of your 1970 trailer, but I'll bet that someone has a good recommendation. Can you post a picture or two? Also, what are you trying to accomplish with the work you are currently doing?
Welcome to the forum!
Steve
Steve Bryant is offline   Reply With Quote
Old 06-21-2014, 05:10 PM   #3
1970 31' Sovereign
Having a hard time uploading a photo. It won't take the URL I'm pasting. Anyway, I'm getting ready to lift the shell off the frame. I was gonna do it with jacks from below to that's why the wraps are now in the way. I guess I could just cut it off at the trim piece and rivet it back on late like the other side.
Old 06-21-2014, 06:09 PM   #4
reinergirl's Avatar
Hollis , New Hampshire
Try the instructions post 7 here
http://www.airforums.com/forums/f138...ics-44928.html
reinergirl is offline   Reply With Quote
Old 06-21-2014, 07:41 PM   #5
1970 31' Sovereign
Duh! Thanks for the link reinergirl!
Here's what I'm talking about. The other side's side panels stop at the trim. I ended up cutting these because I'm gonna lift the shell and need to slide supports under the walls.
Old 06-21-2014, 09:40 PM   #6
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Ask aviator. His 1970 shell off is going very well.
Skatiero is offline   Reply With Quote
What's the worst problem you ran into? Eaglemate On The Road... 16 10-29-2011 05:32 AM
96 land yacht parking brake dilema motorbill Brakes & Brake Controllers 0 09-29-2010 12:05 PM
Local newspaper ran a story Safari Tim Airstream "In the News" 24 08-28-2007 09:56 AM
Electric water heater element: Draining dilema rfield54 Water Heaters, Filters & Pumps 4 05-19-2005 10:07 PM
Ran into a Rally/Caravan j54mark On The Road... 1 04-18-2004 07:19 PM
