Old 06-10-2006, 12:05 PM   #1
1983 27' Excella
French Settlement , Louisiana
Questions re my 83 Exella
Hello to all
I have started polishing my 83 Exella and have about a million questions.
1. Will this ever end ?HA
2 Do you take off the clearance lights and how do you polish them?
3 Do you remove the awning brackets?
4 I have notice that the very front of my RV has bad rock pits, I saw one with the sprayon bed -liner for trucks on the very front acting like a rock guard?
5 About the trim at the bottom where the sides and bellypan meet, do you remove and replace?(mine is lose now)
6 About the blue stripe in the middle what have everyone been doing?
7 The PO has put calking everywhere1/2 in wide?
8 And I can tell anyone that sillycone comes off very easy and the other is stuck, I know what I will put back
9 The airstream letters across the front do you remove and if so how?
all help and opinions will be helpful Billy
housebg is offline   Reply With Quote
Old 06-10-2006, 02:27 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by housebg
Hello to all
Billy,
All these questions area lready answered int eh various polishing threads.
Do a search - you will find more answers then you can even believe...
Uwe
www.area63productions.com
Old 06-10-2006, 02:50 PM   #3
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
housebg, I'll answer # 1 and and #9 just to save you a little searching time.
#1. Does it ever end? No.
#9. Each letter has 2 threaded stems on the back with locknuts behind the skin. The only way to get them off without breaking the stems is by gaining access from the inside of the trailer but since that's not a wise option, I suggest leaving the letters in place and polishing around them as best you can.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Lots of Generator Questions!! lewishw Boondocking 45 03-02-2012 09:12 PM
Greetings and hello with questions rodsterinfl Member Introductions 36 02-24-2012 03:02 PM
Newbie/lurker first post with questions airfun Member Introductions 14 02-07-2012 02:39 PM
Noob with tons of questions! 8string Full-Timing 14 07-20-2011 12:55 AM
A couple Overlaner questions. DougZ 1972 Overlander 2 01-17-2011 05:04 AM
