Old 07-19-2005, 05:07 PM   #1
Not your average Tiki
Tikiman's Avatar
1968 26' Overlander
Columbia , Missouri
Questions from a new AS owner......
Well we just returned from picking up our 1968 26' Overlander. Pulled the AS almost 900 miles through NC, GA, AL, MS, AR, and MO without incident. Upon arriving home I came up with a few issues that I think need to be addressed.
1. The door and window gaskets / seals are shot. I have two or three leaky windows that need to be fixed ASAP. Can anyone recommend where to find the gaskets, material, vendors, etc...
2. Univolt - appears to be the original unit. Is there a quick test to see if this unit is operating properly?
3. Battery - any specific brand or model anyone can recommend?
4. Tires - same type of question, brands or models to use?
Thanks for the help.....
TIKIMAN
"taking tiki to a new level"
Tikiman is offline   Reply With Quote
Old 07-19-2005, 06:35 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
InlandRV.com will have most or all of what you need.
Do a search on Univolt using the search function, and one of the thousand or so posts on this will answer your questions on Univolts.
Group 24 or Group 27 deep cycle RV batteries are the most common replacements. I have always had good luck with Interstate products. Many swear by the new Gel type batteries, but they are pricey. Another good brand that comes to mind are Lifeline batteries.
Standard tire size was 7x15 bias ply, Load range C or D, replacement size is 225/75R15ST, as offered by Good Year, amongst others. ST stands for Special Trailer tire. Goodyear calls theirs "Marathons". Single axle must have Load range D, dual axle can use Load range C for the 60's Tradewind. I'd go with the D-load range, but make sure the rims can take the extra pressure.
If in doubt, post what you have on there now, and the forum will help you spend your money wisely.
Uwe
www.area63productions.com
Old 07-19-2005, 10:07 PM   #3
Tikiman's Avatar
1968 26' Overlander
Columbia , Missouri
UWE
Thanks for the info!
Tikiman
Old 07-19-2005, 11:00 PM   #4
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
A good source for vintage parts is www.oasisrv.com
-Tim
theVAP - Airstream Podcast
Old 07-20-2005, 10:14 AM   #5
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the wonderful world of Airsteam ownership.
I would suggest trying Colelaw salvage which is in Carthage, MO for your parts. You are close enough that you can even drive over and search thier yard. I have posted thier web address below.
http://www.colawrvsalvage.com/default.asp
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
New Owner 74SovereignInt. General Repair Forum 9 05-11-2008 05:20 PM
New Owner "ALMOST" JLD 1974 - 1979 Sovereign 2 01-01-2007 06:57 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
Prospective AS owner with questions jborning Our Community 0 10-14-2002 08:50 PM
