Old 01-02-2013, 10:40 PM   #1
1975 Argosy 22
Abbotsford , British Columbia
Question for the Experts
My 22 foot argosy is languishing in a shell off restoration.Can it be moved with the belly pan and interior skin removed?Will this cause damage to the outer skin?.So I'm wondering if it can be moved without the wood framework inside.
Argosy2 is offline   Reply With Quote
Old 01-03-2013, 07:01 AM   #2
Depends on how you move it.
Old 01-03-2013, 07:48 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Maybe you could install temporary bracing? Double-diagonals, i.e. an "X" brace, made of 24 lumber, fastened to the frames in two or three places? You'd have to install carefully to make sure the diagonals don't touch the skin, only the frame, but they should serve to stiffen the unit.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-03-2013, 08:36 AM   #4
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
If it's "shell off," what are you moving? The shell, the frame, or what?
If the shell is attached to the frame, but with no belly pan or interior skin, no problem--the interior skin adds little to the rigidity of the shell. Once you have moved, however, you need to jack the frame to get it level and flat or you'll never match up the interior skin holes to the ribs.
Zep
Old 01-03-2013, 09:17 AM   #5
1975 Argosy 22
Thanks for your help,the frame is still attached to the floor except for a couple of soft spots I would want to reinforce.
