Question about Zip Dee Flex key replacement
It is time to replace my awning flex-keys.
I have read, and am comfortable with, all the mechanics concerning awning removal, unwinding, removing fabric, re-installing, etc. One point I cannot seem to find an answer to is how to unwind the WINDOW awnings without damaging the AS skin.
Whereas, the main awning has its lower struts (arms) assembled with multiple pieces, where one can remove the lower section(s) and have a shorter arm to unwind with...the window awnings have a single piece lower strut arm. It does not appear that there is enough room, with the awnings deployed, to rotate the arms without hitting the AS skin with the butt end of the arm as you unwind the spring tension.
Has anyone performed this repair and how did you do it?
-Rich-
