Old 03-26-2005, 01:41 PM   #1
Question about Spare/ need help!!
I just purchased a new 2004 16ft, ccd. It has the spare tire, but I can't find the
jack? Does airstream furnish the jack, lug nut rench, and jack handle?
thanks in advance.... mike
imagine is offline   Reply With Quote
Old 03-26-2005, 04:04 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
They did not in '67.
Tom
Old 03-26-2005, 05:20 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
they did not in 1992
john
you call them ferrets, i call them weasels.
Old 03-26-2005, 05:25 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
They did not in 2001 or in 2004.
I think you have your answer now.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-26-2005, 05:35 PM   #5
thanks! that answers my question!! mike/joyce
Old 03-26-2005, 05:43 PM   #6
jcanavera's Avatar
Fenton , Missouri
Images: 143
Not to leave you hanging. The easiest way to replace a tire if you are a tandem axle unit is to run one tire on the same side (assuming you are changing a flat) up on blocks. That raises the bad tire off the ground.
I carry a cross tire wrench, looks like a "+" that has different size lug sizes on three of the four sides. That way I can change tires on the trailer or the tow vehicle with the same wrench.
Hope this helps. Now if you have a single axle trailer its a different story.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-26-2005, 05:50 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Jack
He does, and it is.
Almost any auto parts store will be happy to sell you a hydraulic bottle jack. If you get one, a ten ton would be ideal, not because your trailer weighs that much, but because the jack has a much wider base, so it is less prone to tipping over under load. There should be a spot behind the axle marked "JACK HERE", that is where the top of the jack will need to be. A 2"x6" about a foot long would be a good idea, too, to set the base of the jack on if you are in dirt, and have to raise it there.
Old 03-26-2005, 05:52 PM   #8
jcanavera's Avatar
Fenton , Missouri
Images: 143
Originally Posted by argosy20
He does, and it is.
Thanks Terry, I didn't look closely at the length of his CCD. Good information for a new owner.
Jack
Jack Canavera
STL Mo.
AIR #56
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Need a new tire/wheel for spare. tenrsingr Wheels, Hubs & Bearings 10 02-06-2005 08:58 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Spare tire storage mysilverbullet Our Community 9 10-23-2002 10:35 AM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
