Old 07-25-2014, 06:13 PM   #1
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
Question about handling damage from a leak.
We recently purchased a '77 Overlander that was basically a time capsule. The first rainstorm after our pulling it home showed a wet spot on the floor. We pulled up the linoleum and found wood rot and corrosion in that area. Wood rot has been removed and will be replaced, sealant has been purchased to start working on the seams and windows. The water has been running down inside the wall and my concern is can we seal the seams hopefully eliminating the leak and replace the floor without ripping out the walls? Will it dry out after leaks are sealed if we wait a bit to replace the subfloor in that area? Also is Silflex an adequate substitute for Vulkem if that is all we have available to us at this time? Yes, we are trying to avoid a huge remodel. Any advice is appreciated.
Paddledipper is offline   Reply With Quote
Old 07-25-2014, 07:46 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Get an ice-pick or sharp little screwdriver and work your way around the perimeter of the trailer. This will help you to find how extensive the floor rot has become over the last 40 years. Pay especial attention to the front, rear, and around the door, which is where the 70's era trailers rot the most. Relatively small sections of rotten floor can be cut out, and new subfloor scabbed in. That being said many "shell-offs" were done the hard way (by replacing the entire floor with the shell on)--not recommended.
If the trailer has spent its life in Florida (like mine did), then prepare yourself for a shock. My trailer required a shell-off floor replacement, plus the last 3-4 ' of frame had to be scrapped and rebuilt.
As for how to seal it up, replace all the door, vent, hatch, and window seals, clean up all the seams, and use Parbond, Trempro 634 (Vulkem), or an equivalent to seal (this stuff can be ordered online from places like Vintage Trailer Supply or Out of doors Mart). The plumbing vent pipes are surrounded by a piece of rubber that needs to be replaced about every 5 years--yours is certain to be 40 yrs old, and leaking.
Good luck!
Old 07-26-2014, 03:54 PM   #3
1977 27' Overlander
1996 34' Excella
It is a Florida trailer and is surely showing the signs of it. I bought Silkaflex at Home Depot hit realizing it may have been the wrong choice. We did pull that panel off this morning and were able to see the bolts you mentioned. We hadn't noticed them yet! The insulation was only wet in one spot and not mildewy like I worried it would be. It was very hot and humid today so that is as far as we got but as long as we are moving forward..... Thanks for the replies!
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Old 07-26-2014, 04:49 PM   #4
Belegedhel's Avatar
Houston , Texas
Not sure what Silkaflex is. If it is a butyl or poly based rubbery sealant that remains flexible after setting, then it might be just fine. I haven't found anything at my local Home Depot that was right, but some of them carry different stuff. I did find some grey poly sealant at a local "Do It Right" hardware store that cures to be very similar to Vulkem, but it smells like chocolate fudge while drying. I also had some butyl sealant that was a "gutter sealant" from another hardware store, and I suppose it did its job, but it was messy as heck.
Old 07-26-2014, 05:45 PM   #5
1977 27' Overlander
1996 34' Excella
Name:	ImageUploadedByAirstream Forums1406418257.165703.jpg
ID:	217485. I had spelled it wrong. Click image for larger version
Name:	ImageUploadedByAirstream Forums1406418309.416054.jpg
The Evans' Family
Florida Panhandle
Old 07-26-2014, 05:52 PM   #6
aftermath's Avatar
Spokane , Washington
Our local Airstream dealer sells sikaflex and I have used it to seal up seams. I think it is good stuff but they sell something that looks different from your pictures. Don't know if it is different for the Airstream.
Someone should come along soon with the information.
aftermath is offline   Reply With Quote
Old 07-26-2014, 06:17 PM   #7
1977 27' Overlander
1996 34' Excella
That is why I love this forum :-)
Old 07-26-2014, 08:43 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If u have floor rot but still sorta strong just use Git Rot!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-28-2014, 04:31 PM   #9
1977 27' Overlander
1996 34' Excella
I hadn't heard of that, thanks for the suggestion!
The Evans' Family
Florida Panhandle
Old 07-28-2014, 04:57 PM   #10
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Or on slightly rotted floor you can use West System found at marine stores. It's a penetrating epoxy they use in boats and works wonders to stabilize old wood.
Silver Hawk is offline   Reply With Quote
Old 07-28-2014, 08:50 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Git rot was purchased at West Marine. The West System is similar...at least from their spec sheet I was able to compare. YMMV
It worked great for us.
Channing
WBCCI# 30676
Old 07-29-2014, 07:50 PM   #12
1977 27' Overlander
1996 34' Excella
Sweet!
The Evans' Family
Florida Panhandle
Old 07-29-2014, 08:13 PM   #13
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Marine stores have great stuff!
A lot of great stuff comes from marine stores. To name a few - West System Epoxy, Captain Tolly sealant, all kinds of caulking for outdoors (some of it is for under the waterline so it would last forever in a trailer, etc...).
mhilley is offline   Reply With Quote
Old 08-05-2014, 12:41 PM   #14
Hiawassee , Georgia
sealing floors
I am in the midst of a mini restoration of a 94 Excello and found some damp areas (and some small rotted areas in the floors). After removing the damaged wood, I treated the flooring with a 1 to 5 bleach mixture and let it dry for several days. I then used exterior porch paint to seal all of the subfloor. On a related note, since all of the furniture items were removed, I also took the opportunity to apply a light bleach mixture (1/2 cup to one gallon) to the carpeted walls 4-5 times over a one week period. Took out all of the musty spell from the dampness and left the walls almost new looking. I am now busy searching for the leaks and preparing to install the new flooring.
JumpingJoe is offline   Reply With Quote
does angle affect handling, and other ??? batt Hitches, Couplers & Balls 10 08-05-2012 08:51 AM
how does tongue weight capacity rating affect handling? Smoky Hitches, Couplers & Balls 12 10-06-2008 04:29 PM
TV Emergency Handling - Lane Switch and Slalom TomR Tow Vehicles 38 11-26-2007 11:19 PM
gray water handling darin Waste Systems, Tanks & Totes 2 01-08-2004 09:04 PM
