Just a thought: If there is some air in the lines, sometimes our water pump is noisier than usual.
A pair of brass stopcocks under the waste tank could be the low point drains for your water lines. A single white plastic stopcock could be the low point drain for your fresh water tank.
Rocinante Piccolo is our new-to-us 2016 Interstate Lounge 3500 EXT
(Named for John Steinbeck's camper from "Travels With Charley")
Thanks. Those are under the fresh water tank. But I think those are under the hot maybe.
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
The pump could possibly have been knocked against something or something lying against the pump or one of the rubber feet could be missing. Either condition could cause an unpleasant noise.
Echoing "air in lines" comments. Run hot and cold water from all lines [incl. exterior shower, kitchen sink spray head, and toilet] until no air is left in any line. Sometimes you have to go around the circle again to make sure of this.
