Old 06-09-2019, 01:04 PM   #1
2019 23' International
Portland , Oregon
Pump is noisy after winter storage
Hi. 2015 Bambi. The water pump does not sound healthy. Like bad bearings maybe. Assuming it's kaput, is there a quieter replacement that people like?
While I'm here, what are the two stopcocks under the waste tank for?
Thanks!
leedav is offline   Reply With Quote
Old 06-09-2019, 01:19 PM   #2
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Just a thought: If there is some air in the lines, sometimes our water pump is noisier than usual.
A pair of brass stopcocks under the waste tank could be the low point drains for your water lines. A single white plastic stopcock could be the low point drain for your fresh water tank.
Rocinante is our 2014 International Signature 27FB
Old 06-09-2019, 01:28 PM   #3
Portland , Oregon
Thanks. Those are under the fresh water tank. But I think those are under the hot maybe.
2019 International Signature 23FB "Cecil"
2005 Yukon XL
Former coach: 2015 Bambi 16 "Beanie"
Old 06-09-2019, 08:58 PM   #4
Paradise , Texas
You have air in lines. Fill tank, turn pump on, open all spigots and flush toilets for 30 seconds or more.
As you close each faucet, it will get quieter
Crackerman is offline   Reply With Quote
Old 06-10-2019, 10:54 AM   #5
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
The pump could possibly have been knocked against something or something lying against the pump or one of the rubber feet could be missing. Either condition could cause an unpleasant noise.
jimfa440 is offline   Reply With Quote
Old 06-10-2019, 11:00 AM   #6
Long Island , New York
Echoing "air in lines" comments. Run hot and cold water from all lines [incl. exterior shower, kitchen sink spray head, and toilet] until no air is left in any line. Sometimes you have to go around the circle again to make sure of this.
Noisy water pump xbr443 Water Heaters, Filters & Pumps 11 10-21-2016 03:18 PM
Noisy pump? Check this out. zedex Water Heaters, Filters & Pumps 20 07-23-2011 08:04 PM
Noisy water pump altamont Water Heaters, Filters & Pumps 8 03-31-2008 02:36 PM
New water Pump noisy adonh Water Heaters, Filters & Pumps 10 03-13-2008 01:25 AM
Noisy water pump yukionna Water Heaters, Filters & Pumps 5 04-26-2004 07:11 AM
