Old 05-04-2014, 09:17 PM   #1
2008 25' Safari SS SE
Sunriver , Oregon
Exclamation pulling it level?
I sold my F250 and now drive a 2013 Ford Expedition (with a supposedly heavy duty tow package). The back end of the Expedition drops almost two inches when I hook up my 25 ft Safari and this concerns me. Do I get a sleeve that starts the ball out higher, do I need stronger shocks, or am I okay? Advice appreciated. Thanks.
moj-retired is offline   Reply With Quote
Old 05-04-2014, 09:27 PM   #2
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
sounds like there is no weight distribution hitch on it. If that is the case, you definitely need to get one. If you are using one, then you need to shorten the chain links to put more weight to the front and back trailer
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 05-07-2014, 05:36 PM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
While I don't profess to be an expert, I did watch how they set up my hitch at the AS factory.
First, measure the distance between to road to the inside lip of the rear fender and again the same for the front fender - thus RH1 (rear height) and FH1 (front height)
Hitch up and repeat these measures. - Is the difference the same between front & rear measures - i.e., what is RH1-RH2 and RFH1-FH2. The chains should be tightened to the extent that the differences are the same i.e., RH1-RH2=FH1-FH2. That shows that the hitch weight of the trailer has been equally distributed to both the front and rear axles of the TV. In my case, there was another adjustment having to do with the Reese cam-type anti-sway.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 05-07-2014, 05:50 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What kind of weight distribution setup are you using?
Old 05-07-2014, 08:06 PM   #5
r carl's Avatar
Lin , Ne
What did the front end do?
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
What needed for pulling , 19' to 21' AS ? thombrad Towing, Tow Vehicles & Hitches 40 01-07-2004 02:59 PM
Pulling out a partition wall in a 59 59toaster Cabinets, Counter Tops & Furnishings 4 02-23-2003 03:25 PM
Pulling a Bambi with a Ranger? wallycox Tow Vehicles 42 10-17-2002 01:29 PM
