Old 03-18-2013, 02:38 PM   #1
2006 19' Safari SE
Hayes , Virginia
Unhappy Protechtor Alarm
I have a 2006 Bambi with the protechtor alarm series 2001, for mdl GS-961-LP-RV, MPD 37464 Rev B. I was cleaning the stove and sink area with Clorox, with Teflon and metal cleaner, Nevr-Dull Magic wadding polish. I noticed that the indicator light on the Protechtor was green/red. I reached down and pressed the test button and she started the alarm, beeping for the past 30 minutes--I have found no way to silence it. Turned off shore power, turned off propane, opened the door, turned on the ceiling fan, and put a 24" fan in front of the alarm, blowing out the open door--to no avail.
I called Atwood and they were no help. They did mention that the cleaning material could have caused it and alarm should go off when aired out. No luck....She going off now and would like to get her to shut up before bedtime. Any ideas?
mocus is offline   Reply With Quote
Old 03-18-2013, 02:53 PM   #2
2006 19' Safari SE
Hayes , Virginia
I was in such a hurry I didn't look up Protechtor on the forum. I see other having same problem. Let me check the advice already posted, and will get back if answer not found. Thanks and sorry.
Old 03-18-2013, 03:01 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Fast answer… When mine was acting up, shutting off the 12v power for a minute caused the alarm to reset.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-18-2013, 03:02 PM   #4
2006 19' Safari SE
Hayes , Virginia
Thanks, will check'er
Old 03-18-2013, 03:16 PM   #5
2006 19' Safari SE
Hayes , Virginia
You people are wonderful! Killed the power and walla......Now back to cleaning and getting her ready for the road.....and, who knows...I may set off another alarm!!!! Thanks much, Tom
