Old 05-28-2012, 07:31 PM   #1
mefly2's Avatar
2015 25' FB Eddie Bauer
Propane tank cover ?
Do any of you have a propane tank cover that is not mounted perpendicular to the frame? Ours even has a bit of foam padding between the electric jack post and the cover! It appears to list to the rear and has scratched most of the paint from the frame where it comes into contact.
Old 06-12-2012, 09:32 AM   #2
mefly2's Avatar
Anyone ???
Old 06-12-2012, 09:42 AM   #3
dznf0g's Avatar
Oswego , Illinois
Yes, I use some lengths of 3/8 inch rubber fuel line from any auto parts stroe, about 4" long each and slit them lengthwise. I then slip them over the contact areas (3) with the frame.
-Rich-
Old 06-12-2012, 09:59 PM   #4
mefly2's Avatar
Does yours still tilt? Mine has a cut out for the battery box, but does not fit that far to the rear.
Old 06-13-2012, 08:27 AM   #5
dznf0g's Avatar
Oswego , Illinois
It tilts a little. If I were really picky about it (and now that you have provoked my obcessive compulsive nature...and thanks for that) I would get some thicker walled hose material for the rear sides (only need them at the frame contact locations) and some thinner walled hose for the raised contact area at the jack flange.
I'll get some photos and post in a bit.
-Rich-
Old 06-13-2012, 08:48 AM   #6
dznf0g's Avatar
Oswego , Illinois
Here ya go.
Tilts a little
Front at jack flange
Rear at side
-Rich-
Old 06-13-2012, 07:59 PM   #7
mefly2's Avatar
Very helpful; thank you!
Old 06-13-2012, 08:03 PM   #8
Enthusiastic New AS'r
3campers's Avatar
1985 31' Limited
Glenville , New York
Images: 18
Rubber hose ... simple and brilliant, simultaneously. That's my next mod! Thanks..
1985 31' Limited
2003 GMC Sierra HD SLT 4x4
3campers is offline   Reply With Quote
Old 06-21-2012, 09:13 AM   #9
mefly2's Avatar
I nested some smaller diameter rubber hoses inside of some gray plastic conduit. cut a lot inside the length, and ... painted it black and now have more level / perpendicular propane tank cover. If you need pics, PM me.
