Old 05-21-2011, 06:33 AM   #15
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
Gringo,
Sorry to hear of your issues, but they really are minor issues. I too had door issues, and like you I did not have my stabilizers set correctly. WRT the bubble level on the jack, mine seems to have a mind of it's own. I will get it replaced next time I go to the dealer. As a more permanent fix, I bought a pair of small curved bubbles. I put one centered under the front window to help level left and right. The second one I placed on the street side of the propane cover to level fore and aft. I also keep an old 2 ft level to verify everything. I know some expect the jack level to remain accurate, but remember it usually sits out in the elements unprotected and does get beat up.
The hot water issue could be a simple adjustment at the valve, especially if it only affects the shower. Access shouldn't be to difficult. As an temporary fix, turn the water heater off before/when you take a shower, the water will be hot, but depending on water use it should cool down to help prevent scalding...
drew05 is offline   Reply With Quote
Old 05-21-2011, 06:58 AM   #16
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
To level the trailer I just put this on the front A-frame while running the jack up or down. About $8 and magnetic.
SilverCottage is offline   Reply With Quote
Old 05-21-2011, 07:00 AM   #17
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Originally Posted by Gringo View Post
Those levellers have some authority if you put some arm into it, it seems.
The first thing is to quit calling them "levellers." They are only stabilizers and should not be used to level the trailer in any way.
First, level the trailer using the tongue jack and boards under the wheels on one side if needed. Then, and only then, put the stabilizers down. Crank them only until they are snug. The trailer should not move.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 05-21-2011, 07:04 AM   #18
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The monitor in newer trailers works a bit differently than the old. It indicates the level in all tanks all the time by different colors of one particular led for each tank. You have to ask it to cycle through a process to see the level of each tank the old full-scale bar graph way. Took me a minute to figure that out.
If that's not the issue, look in your owner's manual packet for the booklet on the tank level monitor. I remember there is a calibration procedure for detecting the sensors. That may fix it.
Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 05-21-2011, 08:21 AM   #19
CanoeStream's Avatar
St. Cloud , Minnesota
Use your warranty period to full advantage. I went in for some early fixes on my '06 but definitely noticed that other issues emerged after a year of bumping down the road. Dealers want to help you on this!
You may find your door latch becomes harder to shut over time. They come out of the box only lightly lubed. Use the red tube and squirt some LPS-1 in there when this happens.
As nickcrowhurst always says, "The price of freedom is eternal maintenance."
5 meter Langford Nahanni
Old 05-21-2011, 08:31 AM   #20
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
I appreciate all the comments and help. I definitely have a plan of action going forward on these issues. I will not likely be going back to the dealer where we bought the AS.
And as for maintenance issues....you guys don't know how well you have it. You should try living on a hilltop overlooking the ocean with the trade winds blowing through your home and shop and automobiles 24 hours a day for several years. The brass grommet that comes installed in an aluminum window screen will cause the aluminum to rot and the grommet will fall out within 90 days. As just one example.
Wanna hear about all the different types of stainless steel, and why most of them are a waste of money in a marine environment? Nah....I didn't think so...I have to carefully consider any two different metals being in contact with each other. Like a stainless fastener holding an aluminum roof. Even different types of aluminum....one is going to turn to powder.
The maintenance on this Airstream is going to be like a vacation from maintenance. I actually left a screwdriver out on the ground overnight in Dallas, and the next morning, it was NOT covered in rust! This just doesn't happen to me.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 05-21-2011, 08:41 AM   #21
dwightdi has educated us on the need to properly passivate stainless. And any number of discussions on the galvanic series. And some very knowledgeable folks discussing this.
We'll take as much as you can throw our way.
Old 05-21-2011, 11:07 AM   #22
one of those
Gringo's Avatar
Which stainless are you referring to? There's a lot of it, and it has different characteristics. If you don't want it to rust, then you have to live with it being soft. as one example. If you want it to hold an edge, then it's going to rust. As another.
And putting any other metal, including any kind of stainless, in direct contact with aluminum in the presence of sodium and moisture will start the aluminum on it's way to aluminum oxide.
But that's all neither here nor there. I spent 40 years working on and under the oceans with a variety of sensitive electronic equipment. And now I've lived here for six years. And I thought I knew something about corrosion. hah.
Old 07-19-2013, 08:28 PM   #23
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Always amazes me. Got a problem check the forum. I had the same problem with the door and sure enough the stabalizers were cranked down too hard.
On another note the bathroom water is really hot but the shower not so much but certainly hot enough. No real concerns about that.
TinCan
graysailor is offline   Reply With Quote
Old 07-19-2013, 08:57 PM   #24
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I wrote about using the bathroom door as a leveling tool... then the witty members of the forum suggested a "multipurpose level" a shot glass filled with whiskey set on the kitchen counter. If the liquid fills levelly to the edge, you're level both ways.
...then the discussion turned to "where can I find a 4 oz. "shot" glass...
Don't know if I'd trust the side to side adjustments done by someone who'd emptied that level a few times.
Paula
Old 07-20-2013, 10:03 AM   #25
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Several years ago I bought one of these little babies to use in a AS LY motorhome. I sold the motorhome 3 years ago, but kept this leveller and I use it whenever I set up the trailer - works like a charm. RV EZ Level - Camco RV 20601 - Levels - Camping World
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 07-20-2013, 12:12 PM   #26
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
I bought 2 pair of these and when I set up my Reese hitch on level ground, I set the trailer up perfectly level using a construction level and then applied the stick on bubble levels, One front curb side, one adjacent on the side so you can see both axis measurements when unhitching and operating the jack. One more on curb side near door (we have a 27 FB) and one just above the license plate center rear. They are incremented in inches so one level of Standard leveling blocks = 1.5 graduations. Works well for me. The jack level is fairly useless in my opinion.
http://www.etrailer.com/Tools/Hopkins/HM08525.html -Brad
SuperTrouper is offline   Reply With Quote
Old 07-20-2013, 01:28 PM   #27
gtc6452's Avatar
2015 27' Flying Cloud
2011 30' International
mooresburg , Tennessee
rv ez level by camco, works great.
gtc6452 is offline   Reply With Quote
Old 07-21-2013, 07:41 AM   #28
LONDON , ON
I use a magnetic 8" torpedo level from Sears that I keep in the trailer and set on the front trailer frame when unhitched for front to back leveling. I then set it on the battery box to check side to side level.
Simple, cheap, and I don't have to mar the beautiful exterior.
Went to buy 2011 27FB, ended up with 2012! 18driver 2011 - 2015 International 71 06-21-2013 03:22 AM
Shower drain question 27FB Gringo 2011 - 2015 International 14 12-17-2011 01:32 PM
