Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 05-05-2004, 09:31 AM   #1
Ufatz
Profile:
Exclamation Prices too high?!
I am a little concerned about something and seek comment from members. I have always heard that Ace Fogdall RV is a great place for Airstreamers to have work done. I dragged my trailer over 400 miles to the place for some needed repairs and some items I thought I might want done. First quote I got was for a new furnace and installation: $950! Now, I know Camping World sells the furnace for $512 or less and charges $145 to install it. With my Presidents Club discount it would be less than that. Why so much higher from A.Fogdall? The quote was "new furnace $650 and $350 to install it, due to modifications to get the furnace in place." Huh? What the hell is that all about?
I am planning on having a new water heater installed and some other work and my trailer is sitting there right now, a full days drive away. I am very nervous that I am being set up for a fleecing!
Any comments?
Ufatz is offline   Reply With Quote
Old 05-05-2004, 09:44 AM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
No personal experience, but I have heard Camping World is not real thrilled to work on Airstreams. You may want to contact them to see if the $145 install charge also applies to Airstreams.
Ace Fogdall, I believe, is more of a Mom & Pop operation, so I would expect their product prices to be higher.
What kind of Airstream do you have?
Old 05-05-2004, 10:12 AM   #3
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
ufatz,
You must be more specific if you want precise feed back.
What year is your trailer? What size trailer and furnace?
New furnaces are different, will not just pop in and work. The Airstream has ducted heat, which the furnace must be adapted to. One must literally use component from the old furnace, and fabricate a well fitting manifold on which the new furnace will sit.
The exhaust and air intake will likely be different also, so now you're talking skin work.
$ 350.00 is a bargain, if you ask me. This is a full day job for an owner, and close to that for a RV technician.
The price of the furnace is questionable, Again, you must specify which furnace they're quoting.
I would bring these questions to Ace Fogdall, if they're sincere, they'll explain "why so much".
Uwe
Old 05-05-2004, 10:22 AM   #4
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
UWE brings up some very good points.
Airstream model and age?
Furnace model?
At $65 dollars an hour that comes out to only a little over 5 hours of labor.
Revising ducting, wiring...etc is pretty time consuming.
And Camping World will not touch your Airstream if it is an older model. They don't even like working on newer ones.
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 05-05-2004, 10:24 AM   #5
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
i have used camping world and haven't had any problems. if they do it will be done right. air cond units are a little more complicated . they will install a ac with a new drain pan or no drain pan. reason given old pans break in the removal process. you must provide the drain pan, camping world doesn't have a source for the pans.
RV dealers charge max retail and max labor. so go get your unit and take it to cw if money is an issue. i would be calling cw and making an appointment to get furnace and hot water heater replaced. probably both items will require some cabinet removal to remove and install the furnace and hot water heater. that is why cw doesn't like airstreams.
the price they quoted is probably the norm for the rv world. i haven't used fogdall but i have heard they do good work.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
wb13798 is offline   Reply With Quote
Old 05-05-2004, 10:27 AM   #6
wb13798
wb13798's Avatar
rv dealers here get $78 and up. i think jackson center upper their labor prices.
AL
allison 6 speed
Old 05-05-2004, 10:37 AM   #7
uwe
418
uwe's Avatar
Images: 40
Honestly, the local camping world does not impress me the least bit. Most of their basic merchandise seems cheesy, same stuff as Walmart, just more of it. And what's with the time share and insurance guys bugging you inevery other isle....not my thing.
I have no experience with their service dept. As they would not even install a Winegard in place of an old winegard for me. I bought it elsewhere and did it myself in 45min.
Uwe
Old 05-05-2004, 11:21 AM   #8
Cedars
Cedars's Avatar
Profile:  1983 31' Excella
Waterloo , Iowa
There is an alternative to Ace fogdal in the same area..... RV Revive, an independent shop owned and operated by a former Airtream technichian. Ryan has done all our work, and we could not be happier. He's the kind of guy that tells you what is needed, and is willing (more than willing, actually) to ell you what you need to do the job yourself. However, he has 17 years of experience as a tech at Ace Fogdal.... check out the site here:
http://www.rvrevive.com/
I will tell you this, I just called RV Revive and asked the shop rate.... Sherry said it is $74 an hour. Then I call Ace Fogdall and asked the same thing. They said they couldn't tell me that as things are flat rated, they quoted by the job, and she didn't know what the hourly rate was. Hmmm. That kind of thing never makes me happy.
Ryan's charges might seem high for an hourly rate, but I'm only charged the actual time he invested.... if a job books for 2.5 hours, and he does it in 1.6, that's all I pay for. And I've never known a compentent mechanic that couldn't beat the flat rate by a considerable amount!
Elizabeth in Iowa
The carpeting is gone! The carpeting is gone! Long live the cork floor!
Cedars is offline   Reply With Quote
Old 05-05-2004, 11:41 AM   #9
uwe
418
uwe's Avatar
Images: 40
Elizabeth in Iowa
I believe that a competent mechanic, beating the flat rate time, deserves to be paid. He only beats the time if he/she knows what they're doing, which means they already paid to learn this, why should'nt the customer?
I prefer flat rates, because often things go wrong, and they actually work overtime on the flat rate pay, which is in your favor. This happens especially on older trailers and cars.
It has been my experience that "time and materials" jobs turn out way more than a flat rate.
I am not trying to discourage from using Ryan's services, just wanting to add my experience to the equation.
Uwe
Old 05-05-2004, 11:42 AM   #10
mtpalms
mtpalms's Avatar
Profile:  1971 23' Safari
Joshua Tree , California
We have decided to install BAL stabilizing jacks and although we are waiting for the hardware that was supposed to come with the jacks, among other misadventures, we'll be installing them ourselves.
The cost of the jacks, which are especially made to fit Airstreams cost us $183.00 plus $27.00 shipping from the retailer. When I talked to a BAL representative to find out what type I needed, she quoted me an msrp of over $250. Looks to me like a 2 hour job for people like us who will be doing this the first (and I hope, only time), which would be $150 labor at my husband's rate. so we're in it for $ 360.
I searched the forums of course to bone up on these things, and one person posted a little over a year ago that his local AS Dealer quoted him over $600 to install them on his Overlander. Other posters said that AS dealerships quote the jacks themselves at $204. Some have posted that Camping World has them as cheap as $154 w/ $20 shipping. In the Overlander's case, I don't know why a dealership would quote such a high price for installation, except maybe that trailer needs a special repair or modification before the jacks can be installed.
The trouble with chains like camping world is that you might have a great experience at one, and a total disaster at another. It's no guarantee, but an AS dealership or authorized service shop will give you the best work because they know what your trailer requies - for some it is worth shelling out the extra dinero.
Labor can really add up - if you can do some of it yourself, like removing an old air conditioning unit yourself before the repairman installs the replacement, you can save quite a bit. Other times people are so inept that they end up doing more damage and costing themselves more money than if they let the repairman do it all.
mtpalms is offline   Reply With Quote
Old 05-05-2004, 07:01 PM   #11
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Prices too high?!
I prefer flat rates, because often things go wrong, and they actually work overtime on the flat rate pay, which is in your favor. This happens especially on older trailers and cars. It has been my experience that "time and materials" jobs turn out way more than a flat rate. I am not trying to discourage from using Ryan's services, just wanting to add my experience to the equation.
Uwe, I wholehartedly agree with your statement. After having started out in the collector car arena then joining the Vintage Airstream contingent, I too have experienced the unexpectedly large bill when working on the "time and materials" jobs when comparing similar work done on the "flat-rate" with both my 40-year-old Airstream and my 39-year-old Dodge. It is often a real scavenger hunt to find dealers and other service providers who are qualified and willing to work on a collector car or Vintage Airstream - - it is one of the reasons that I have been a customer of my favorite Airstream dealer (Ace Fogdall RV) since the mid-1990s, and my favorite automobile dealer's service department since the late 1970s. It also helps that with both my Airstream dealer and my automobile dealer I have never had to take a unit back to have the same problem addressed more than once - - in both cases, I am a very satisfied customer.
Kevin
Kevin D. Allen
AIR #827
Old 05-05-2004, 07:16 PM   #12
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
I agree with previous poster about Camping World. I had a very solid, professional experience with one in Virginia (as an out of towner) and have had two disappointing service experiences with the local one in Denton Texas. Both times, had appointment with detail on work to be done. Got there and found out they did not have the right parts to complete the job. Took the trailer to a local independent who immediately called out for the parts and installed. Service and professionalism is specific to the leadership managing that particular shop. I've also had good experience with the local Airstream Service shop in North Dallas.
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
Tin Hut is offline   Reply With Quote
Old 05-06-2004, 05:10 AM   #13
Ufatz
Profile:
Follow up to Price to High post
I have spoken again to Steve Oldani at Ace Fogdall and we have the work scheduled. Just to share information with you, my trailer is a 1988 Excella 29'. We have added Pergo flooring and have all awnings, Polar Shield, two Fantastic Fans etc. It is our second A.Stream and we have had it for six years. The total to replace the furnace is going to be right around $1000. Probably $750 to install a new DSI water heater. Steve tells me that in each case "modification" and "fabrication" is neccessary to get the new appliances to fit. A shredding rear tire ripped off our dump handles and tore our a two foot section of aluminum around the body (rocker area I'll call it) To repair that "requires" dropping the pan AND the tanks so the valves and the valve dump handle extensions can be repaired. Another $1000.
I share these costs with you without comment and only so you will have an idea what it may cost you someday to have this sorta work done.
Warren W. Wiley
Old 05-06-2004, 06:28 AM   #14
mandolindave
mandolindave's Avatar
Profile:
Yeah, the cost of repair is high. I had my water heater replaced and there was
some modifications needed to be done to the water lines. The new heaters have
hook ups in different places. It would have taken me much longer to get the job done myself, and I figured I would do better working and getting paid, and leave the
job to someone who has the tools and experience.
mandolindave is offline   Reply With Quote
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Parts Prices Janet's Husband Rock Guards, Segment & Window Protectors 1 01-23-2004 02:43 PM
Seen the SOB prices lately? TomW Trailer Values 1 01-10-2004 09:46 AM
Thoughts on quality and prices ipso_facto Our Community 4 04-29-2003 08:04 PM
sky high prices overlander Our Community 17 10-09-2002 03:52 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
