Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 05-06-2004, 07:31 AM   #15
j54mark
Profile:
Originally Posted by Ufatz
I The total to replace the furnace is going to be right around $1000. Probably $750 to install a new DSI water heater. Steve tells me that in each case "modification" and "fabrication" is neccessary to get the new appliances to fit.
For my own education, could someone who has been there and done that tell me what "modification" is required to replace the furnace in an '88 Airstream? I would have expected that to be an NT30, and a new NT30 is an exact fit. I thought.
Not trying to accuse anyone of anything, just looking to expand my knowledge.
Mark
Old 05-06-2004, 08:08 AM   #16
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
IIRC in the mid to late 80's Airstream changed to the cassette style furnace that is now in use. The only problem is the original manufacturer of the furnace used is no longer making them. So to replace it requires a new install from scratch. Lots of additional work. The PC boards are available but not the whole furnace. I want to say the OEM was a Dometic, and now the manufacturer is Suburban, but I could be wrong on that.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 05-06-2004, 09:59 AM   #17
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Airstream has use "Suburban" furnaces since 1966.
Replacing them with a new style requires some additional work in order to continue to use the Airstream installed "ducts."
It is not that difficult for someone that has the tools and knowledge, but the replacement is not just a "slide in" job.
Depending on the model, a change out can take 4 to 5 hours.
Depending on the source, a new 30,000 BTU Suburban furnace costs around $625.00.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 05-06-2004, 10:30 AM   #18
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Mark
The furnace lives in side a metal housing, which has 2 parts, spot welded together. The upper part is the furnace enclosure. It sits tightly inside a cutout in the inner skin. The lower part is shallow, and the ducts are connected to it.
Furnace replacement requires for the furnace cassette to be slipped out of the housing, and then ultimately housing removal.
The upper part of the housing needs to be separated fro the lower part. ( chisel, or small die grinder, or in my case, both.
Now you have essentially a steel pedestal, 3 in high, with an open front, and ducts connected to the sides.
The new furnace goes on top, and depending on the installation, provisions must be made for the new furnace to discharge air into the old "pedestal" or manifold, if you will. Either by cutting holes in the top, or by creating a duct the will channel the hot air from the furnace into the front of the manifold.
I hope this explanation makes sense. It's obvious once you look at it, but hard for me to explain.
I did not replace my furnace, but removed it due to it being rusted out. I did save the front cover and reinstalled the lower part for future use.
Do not throw these parts away if you remove your furnace. They will be needed to make a new installation easier.
Uwe
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 03:29 PM
Parts Prices Janet's Husband Rock Guards, Segment & Window Protectors 1 01-23-2004 03:43 PM
Seen the SOB prices lately? TomW Trailer Values 1 01-10-2004 10:46 AM
Thoughts on quality and prices ipso_facto Our Community 4 04-29-2003 09:04 PM
sky high prices overlander Our Community 17 10-09-2002 04:52 PM
