Old 02-12-2013, 06:40 AM   #1
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
Preventing the rodent super highway
I am getting ready to re install the duct work for the furnace. before dismantling the mice had been using this as a highway for high speed commuting from one end of the trailer to the other. I noticed that there are holes in the bottom of the duct that match holes in the floor. one at front into the water tank compartment. I assume to keep the water from freezing. but there are two at the back that don't seem to go anywhere in particular. any idea what these were for?
Any reason I should not put some wire mesh over the holes between the floor and the duct to help prevent the rodents using it?
dkrukosky is offline   Reply With Quote
Old 02-12-2013, 07:12 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The holes in the back could be for heating the black and gray tanks.
Richard
Old 02-12-2013, 07:39 AM   #3
1982 34' Limited
Harrowsmith , Ontario
I would imagine that as long as the mesh is metal and doesn't restrict the flow that there would be no issue at all with that. It's a great idea, I'm going to do it to mine when I put the bathroom back together!
BradB is offline   Reply With Quote
Old 02-12-2013, 05:16 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
Oh, I like that . . . mesh out the tank heat tubes. Good idea! Thanks! I'll do it at the clamp site.
Old 02-13-2013, 04:27 AM   #5
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
So are there some kind of tubes that run from the back holes to the waste tanks?
Old 02-13-2013, 09:17 AM   #6
Splitrock's Avatar
For my trailer, there are two 2" tubes that come off the heat ducts and go into the belly to heat the tanks. The one I removed was not screened at the factory.
Old 02-13-2013, 11:11 AM   #7
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
Tank Tubes
so is that one tube for gray and one for black tank?
Old 02-13-2013, 02:06 PM   #8
Splitrock's Avatar
One is for fresh water and one, I believe, is shared between the black and gray. Both would be rodent tunnels.
