Old 08-27-2013, 10:25 AM   #1
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
Prep to apply numbers
Just received my WBCCI packet with my vinyl numbers for our 2014 AS. What should I use to clean/prep the aluminum surface for application?
Will
#31443
Don't follow me.
I've made a life of leading folks astray.
Will_Brule is offline   Reply With Quote
Old 08-27-2013, 10:28 AM   #2
1971 29' Ambassador
Leonardtown , Maryland
soap and water and leave wet and soapy while placing numbers in the desired locations
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 08-27-2013, 10:57 AM   #3
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
I found that going to Fastsign and having them make a continuous sheet with our numbers was much easier than trying to apply each number individually.
kswelsh is offline   Reply With Quote
Old 08-27-2013, 11:26 AM   #4
dznf0g's Avatar
Oswego , Illinois
Before using the soapy water, I'd get some PrepSol (or similar brand prep solvent) and clean any wax, etc. off.
-Rich-
Old 08-27-2013, 12:12 PM   #5
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Like kswelsh, we had a quick sign company make a one-piece, peel-and-stick number set for us. Washed the aluminum with mineral spirits to make sure all the road oil was off, dried the area. Drew a light pencil line level with the nameplate and applied. They still look great after many storms and two hard winters.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 08-27-2013, 12:26 PM   #6
extiger's Avatar
2011 30' Classic
Kingwood , Texas
On my first AS put the numbers on individually, PITA. Cleaned surface with soap and water. 2nd AS took the numbers to a sign company and they made a one piece pull and stick. Actually there was backing on both sides, so you pull off the backing on the stickem side and place on AS. Then pull the top side backing off. Much easier. On 2nd AS used glass cleaner as the dealer recommended it for final cleaning of the AS.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
