Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 08-29-2013, 07:00 AM   #1
2011 25' FB Flying Cloud
chalk hill , Pennsylvania
Power Jack
Hello,
2011 Flying cloud. Trailers been sitting with no batteries since last winter. Charged batteries and the jack seems to have no power The light on the jack does not work either. Fuse looks fine. Any ideas on what to check for.
thanks,
Dave
Getahobby is offline   Reply With Quote
Old 08-29-2013, 07:42 AM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
For electrical troubleshooting we should always have a cheap test light or voltmeter handy. Make sure power is getting to the unit before looking to trash it. You can check the fuse too. Sometimes the bad fuse is just not easy to see. Check switches too.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 08-29-2013, 07:50 AM   #3
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Haines , Oregon
Did you hook up the jack when you reinstalled the batteries? It is directly connected, and it can be easy to miss the wire.
Old 08-29-2013, 08:30 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Just because the fuse looks good doesn't mean it is. If you have a spare fuse, pop it and see if it works. That's another quick test.
Old 08-29-2013, 08:36 AM   #5
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
If you are able to plug in the umbilical cord from your tow vehicle do so. If it work then you have isolated the problem to the batteries and wiring in the trailer
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 08-29-2013, 08:43 AM   #6
Mantua , Ohio
As Drat said. Some AS have a direct wire to the battery from the jack. It took four supposedly smart owners including me to figure that out at TOG a few years ago. Jim
Old 08-29-2013, 08:49 AM   #7
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Switch in my 2010 went out, received a new one from company no problem.
jkcru is offline   Reply With Quote
Old 08-29-2013, 08:50 AM   #8
Free Range Human
Drathaar's Avatar
Haines , Oregon
I'm having a hard time seeing how this will isolate trailer wiring. On both of my trailers, the jack is directly wired to the batteries, with just a inline fuse as the only thing between batteries and jack.
I will second the advice to have a multimeter in your tool kit. Use the ohm meter function to check fuse continuity, and the volt meter function to see if you have 12 vdc at the fuse, and at the jack head.
Old 08-29-2013, 09:59 AM   #9
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Interesting to see that some of these switches have direct battery connections. On my Classic, it runs through the 12 volt system. The way I know is that the jack will not operate if the master disconnect is in the off position.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-29-2013, 10:59 AM   #10
Free Range Human
Drathaar's Avatar
Haines , Oregon
Jack
Jack, I suspect that is because you (probably) have internal batteries in the Classic. The others like mine have an external battery box.
One thing I have noticed is it's easy to pull the inline fuse case apart when reinstalling the propane cover. I've done that a couple of times. Maybe time for a spade type fuse and case.
Old 08-29-2013, 09:47 PM   #11
jcanavera's Avatar
Fenton , Missouri
Images: 143
Good point I didn't consider that!
Thanks!
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-29-2013, 11:39 PM   #12
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
If you read the very small writing on the elect jack stem, it tells you what to do to reactivate the connection on the jack.
right off the bat, you DO need to connect the umbilical cord to the truck. You should also have a thin black wire that connects with the positive cable to one of the batteries. But you have to connect to the 7 pin connector.
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 08-30-2013, 05:43 AM   #13
I'm a dummy. I had the that black wire hooked up to the negative terminal. Being black I thought it was a ground.
thanks,
Dave
Old 08-30-2013, 01:56 PM   #14
Free Range Human
Drathaar's Avatar
Haines , Oregon
thanks,
Dave
Dave, we've all done stuff like that. Just be thankful you didn't hook ground to the positive terminal. That gets exciting in a hurry (don't ask how I know).
I'm glad you got it fixed!!!
Old 08-30-2013, 02:01 PM   #15
Free Range Human
Drathaar's Avatar
Haines , Oregon
Can you explain that???
I can think of no reason why the umbilical needs to be hooked to the truck. On the FCs and Safaris that I have seen, it's a simple DC series circuit, with power coming directly from the positive terminal of the battery, and I suspect that it is frame ground (although, it could also have a ground wire going directly to the negative terminal). I am away from my FC, so I can't verify which.
Old 08-30-2013, 03:57 PM   #16
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
As long as we are here let me ask this ...New electric jack, wired to power from the vehicle. Jack only works when the vehicle key in on the "on' position, and the 7 way connected. Unplug the 7 way and no power to jack. It seems to me that the electric jack and it's light, should work at all times whether hooked to TV or not. Am I correct in assuming I should run a black wire back to the + battery in the rear to have full time power?
Barry
goshawks00 is offline   Reply With Quote
Old 08-30-2013, 05:05 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Barry
Why did u wire to TV to jack? Do you have battery in AS?
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-30-2013, 05:21 PM   #18
Free Range Human
Drathaar's Avatar
Haines , Oregon
Barry
Barry, assuming there is only a single wire, then yes, it should go to the batteries (positive terminal). Check your documentation. But yes, the jack should work at all times.
I've never heard of the jack being connected via the umbilical. That could make for some awkward moments when the ball is above the hitch.
Old 08-30-2013, 06:27 PM   #19
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Channing I didn't say I wired it, I said that is the way it's wired, and yes there is a batt. in the trailer. Thanks Drat. I will rewire it to the batt. tomorrow I hope. It's always nice to get help rather than silly questions with out positive content.....
Old 08-30-2013, 08:41 PM   #20
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Kewl!
Not trying to diss ya!
Channing
WBCCI# 30676
