Old 05-24-2019, 02:31 PM   #1
LAKE IN THE HILLS , Illinois
Question Potable water tank
What is the best way to sterilize and how long can water be held before it is necessary (recommended) to do so?
Royboy is offline   Reply With Quote
Old 05-24-2019, 04:34 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We drink the water from our tank so I like to think we take pretty good care with it. When planning on our run towards home I try to let the tank run down to somewhat less than half full. I add a little bleach ( maybe 1/4 c or so) to let it slosh around on the way home. Once home I run the sink faucets to let it flush through the lines and drain the tank. This is all I've done and things seem to be in pretty good shape. When filling the tank away from home I always taste the water before filling just to make sure it's good water. I always travel with some water even if not full.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-24-2019, 08:09 PM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
WATER – CHLORINE BLEACH RATIO FOR PURIFYING DRINKING WATER
(Bleach containing 5-6% Sodium Hypochlorite)
numbers are ’rounded’
1 Quart water, 2 drops bleach
1 Gallon water, 8 drops bleach
5 Gallons water, 1/2 teaspoon bleach
10 Gallons water, 1 teaspoon bleach
50 Gallons water, 5 teaspoons bleach
(Bleach containing 8.25% Sodium Hypochlorite)
1 Quart water, 1 drop bleach
1 Gallon water, 5 drops bleach
5 Gallons water, 3/8 teaspoon bleach (or three 1/8th teaspoons)
10 Gallons water, 3/4 teaspoon bleach
50 Gallons water, 3.5 teaspoons bleach
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Potable water tank nasty jeepguy Fresh Water Systems 5 07-21-2009 09:57 AM
Potable water tank- How many gallons? Zstream Fresh Water Systems 0 07-02-2009 05:40 AM
Potable water tank drain annie oakley Waste Systems, Tanks & Totes 1 05-26-2009 04:17 PM
City Water Connection to Potable Tank? Motoman Fresh Water Systems 2 12-19-2006 06:22 AM
Potable Water Tank Lee Pace Fresh Water Systems 4 09-01-2004 07:44 PM
