Old 04-12-2016, 07:03 AM   #15
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I had JC remove the battery boxes entirely. I provided them with stainless steel trays, which they screwed into the frame and strapped down the AGM batteries. Tey then replaced the plate (the front panel that goes from the window down to the frame) and they sealed up the area where the battery boxes were with insulation and aluminum. Works just fine. Here are the before and after photos:
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
HItch ball height via AS and via Leveling mefly2 Hitches, Couplers & Balls 5 03-13-2012 01:56 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
