08-10-2014, 12:41 PM
Portable gas heaters
What's your favorite portable gas heater, and why?
And how do you use it? Cannister, gas line, indoors, outdoors?
I occasionally need heat for my 28' AS, and I want to be able to use it at higher elevations.
08-10-2014, 01:05 PM
And since my wall furnace is broken, can I just pull it out and use the space for storage?
08-10-2014, 01:17 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
I use a little buddy portable catalytic heater which uses the small propane canisters. It was cheap and is portable. I do not use it while I am sleeping as I just do not trust it (I really want to wake up!).
Dan
08-10-2014, 01:30 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Sorry, I have to say it.
I wouldn't use any unvented heater in a trailer.
08-10-2014, 03:30 PM
We have the "Big Buddy" portable heater and really like it. It uses 2 of the small camp stove size propane bottles and the great thing about it is the built in fan that works off 4 D cells (you can get an A/C adapter for this fan also). The fan really pushes out the heat. This heater works well for taking the chill off in the morning. I like to set it in front of me sometimes when I'm sitting on the couch to warm up my legs (this is the advantage it has over stationary wall mounted catalytic heaters). The noise it produces with the little fan is quite pleasant compared to the
trailer furnace. The down side is that it is one more thing taking up space.
Like Touring Dan has said we don't use ours when sleeping. We set the furnace on 50 and when hooked to shore power use our electric blankets or a ceramic electric heater. I think you will read posts of those who crack a couple windows for ventilation and do use the catalytic heaters while sleeping, but we don't want to chance it I suppose. I sleep too soundly and there is also more of fire hazard I feel, in addition to asphyxia concerns.
Am thinking you may want to go ahead and get a new furnace for peace of mind when the temperatures drop into the teens. You will get good heat circulation throughout the trailer and not have as strong of concerns over freezing water pipes.
My two cents, Pat
Sun City Center, FL
1988 25' Excella
08-11-2014, 06:13 AM
1987 32' Excella
Nepean
, Ontario
We have a blueflame heater mounted on the side of the cabinet that houses the stove (at the entrance). As mentioned, however, it is critical that there is a source of fresh air when it is in use - so we open the vent over the stove and the vent in the bathroom in very cold weather, or we open the kitchen window.
The blueflame heater can be purchased through Amazon on-line for about $125. The nature of the blueflame is that it is a convection type of heater, drawing cold air in at the bottom, passing it alongside the flame which is between tempered glass, and warm air exits through vents at the top. This heater provides warmth throughout our 32-foot Excella, even the bedroom in the back. However, read the caution - and note that it is not recommended for RV's.
As an addendum, the blueflame heater is preferred by the hardcore boondockers, as it does not draw down batteries (no fan, no electrical connection). Two winters ago we dry camped in Quartzsite AZ for 2 weeks when the overnight temperatures dropped to 25F with daily highs around 40F. We were comfortable and did not experience any freezing pipes (we left the cabinet doors open in the kitchen and bathroom).
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
08-11-2014, 04:10 PM
I thought the danger of carbon monoxide from the furnace was a bigger threat. Am I wrong? Don't you leave a window cracked when running the furnace, too?
I was looking at the Olympic Wave catalytic heater. I thought I could use it inside AND outside. Inside - when boondocking in the mountains (w/a window cracked). Outside - at bluegrass festivals.
What's the price difference between a 15k BTU A/C vs. a heat pump? Also looked at an A/C with "heat strips" but the shop said that wouldn't provide much heat.
08-11-2014, 04:39 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Originally Posted by mommythrice
I thought the danger of carbon monoxide from the furnace was a bigger threat. Am I wrong? Don't you leave a window cracked when running the furnace, too? ~snip~
As long as there are no cracks in the combustion chamber(s) a furnace does not put CO into the trailer, it is exhausted to the outside, just like your home furnaces.
Aaron
WBCCI #XXXX AIR #2495
08-11-2014, 04:40 PM
Mantua
, Ohio
Many AS had catalytic heaters in them in the past. They worked very well. Not a new idea! Jim
08-11-2014, 10:12 PM
1972 31' Sovereign
Benton
, Arkansas
I look at it this way, I wouldn't feel comfortable letting my kids use my trailer with an unvented heater.
This says something.
08-11-2014, 10:32 PM
1999 34' Excella
Hillsboro
We have the stock heater. When it fails I will replace. Also have heat pump for the marginal days.
I almost died in a camp with one of those catalytic heaters... I only use outside now.
Peace and Blessings..
Channing
WBCCI# 30676
08-12-2014, 07:47 AM
1987 32' Excella
Nepean
, Ontario
In all cases you should have a CO monitor in your AS - we installed a combined smoke/CO alarm.
As well, it is a safe practice to always have a source of outside air through an open window or vent.
When dry camping, there is insufficient battery reserve to power the furnace fan, so running the furnace on a cold night will probably cause the batteries to deplete to the point that you may not have enough power to run anything else - remember that your water pump draws 3 amps, and that your lights and refrigerator need power as well, even if only some for monitor circuits.
While unvented heaters present risks of CO and CO2, having some open ventilation (opened window and/or vents over the stove/shower) in conjunction with a CO/CO2/smoke alarm is safe and is practiced by boondockers. That said, there are then 2 types of unvented heaters: the radiant (catalytic) heater and the convection (blueflame) heater.
The radiant heater radiates heat directionally away from it - the catalytic heater has a slightly red glow to it, and unless facing it directly, there is limited heat. When we first got our AS, the PO had one attached to the side of the stove at the entranceway. When sitting on the gaucho curbside you were warm, but if sitting streetside there was no warmth. A second type of radiant heater is the brick heater. It has ceramic bricks which are heated by the flame to glow red hot. While it does provide a better radiation pattern than the catalytic heater, there is always the inherent danger of accidentally touching the heater and burning yourself. We travel with 2 dogs and this nixed type of heater.
The blueflame is a convection type of heater. The body of the heater is cool to the touch, although it is quite warm at the top where the warm air vents. When I first had my LY motor-home, the boondockers in Quartzsite all recommended the blueflame, and I bought a free-standing one that had a flexible gas line. It worked well and I was pleased with it. When I purchased my current AS - Excella 32 foot - it had the catalytic heater already installed by the PO, so I used that at first. I found that only the gaucho up front was warm, but the rest of the trailer was cold. So I replaced the Olympus Wave catalytic heater with a Procomm blueflame heater. We are comfortable with it. In fact, we use it even when we are hooked up, as it is much more efficient than the furnace (remember, we do pay for propane).
VE3JDZ
AIR 12148
WBCCI 8080
08-12-2014, 09:04 AM
That's why I need a gas heater. I can use HP or even and electric space heater when we have power - which is most of the time. But when we're camping in the mountains I want to stay as long as possible. It's usually warm during the day. I just like to take the chill off before I go to bed and again in the morning when I get up.
Thanks for the explanation. I didn't realize there was a difference!
08-12-2014, 01:35 PM
Wise Elder
2010 30' Classic
South of the river
Unvented heaters are hazardous. People have died. I've written about this before and while I realize opinions vary and people's safety standards vary, I don't think they're safe and wouldn't recommend them, particularly in light of the better alternatives available.
The main hazards posed are fire and CO poisoning.
Catalysts deteriorate with age and use so an installation that produces little CO while new will produce increasing amounts of CO over time.
Cracking a window seems like a sufficient procedure and easy enough to perform, and it is while fully in control of one's faculties on a cool, clear evening.
But if you've come down with the flu, have a pounding headache, can't seem to get warm, and there's a storm outside, you might forget or decide it isn't worth it.
There are all kinds of alternatives. Yes they cost money and take effort to install.
http://www.airforums.com/forums/f427...ers-72237.html
http://www.airforums.com/forums/f427...ity-74936.html
The furnace in my Cayo doesn't use any electricity.
The furnace in my Airstream uses quite a bit. I added another battery and a ready means of charging the batteries from the truck.
08-12-2014, 03:40 PM
Broadway
, North Carolina
Adding a cataltic element reduces oxygen consumption. But even if the catalytic element did deteriorate, the heater would consume oxygen at a rate similar to any other propane heater.
CO is only produced when the oxygen in the room is depleted. That is why most portable propane heaters now have oxygen depletion sensors.
The oxygen depletion sensor in a portable propane heater makes it less of a CO risk than our propane stoves....probably even than our central factory furnace, because a cracked heat exchanger could also delete oxygen and possibly lead to CO production.
Everything in life is a calculated risk.....like sleeping in a tiny aluminum capsule that has
- 80 lbs of propane sitting atop 2 lead acid batteries outside the front window
- an open-flame water heater under the starboard bunk
- a stove with 3 open flame burners on one side of the galley
- an open flame fridge on the other side of the galley heating ammonia gas
- a propane furnace burning brightly in the aft compartment.
Come to think of it, that $100 Mister Heater with an oxygen depletion sensor is probably the safest thing on board.
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
08-12-2014, 03:44 PM
1974 Argosy 20
Kooskia
, Idaho
My cousin, his wife and baby daughter were all asphyxiated in a tragic CO accident at their summer home (not RV related). One of the reasons the investigators figured they didn't go outside for help is they all had symptoms of severe flu, but that is how CO comes on, headaches, nausea, vomiting. See Jammer's comments above....
A number of years ago two brothers attended a WBCCI rally in my then home unit. They used a stove top burner for heat apparently. One did not make it through the night. A stove top burner is the same as any unvented heater as far as how it uses oxygen and can produce CO.
And yes, thousands of people have used the unvented heaters with no problems over many years. But there is a sound reason that they are not legal or RVIA approved for use in Recreational Vehicles and never come as factory equipment.
Please understand the dangers of them very well prior to using them in your own RV. You may decide the risks are not worth the benefits. Spend the money you would pay for a non approved propane heater on upgrading your electrical and battery system, for example, and use the original CO safe furnace. (assuming it is in fact rust free, hole free....I had one which was not, and what headaches I got, until I figured the problem out. It was replaced of course).
08-12-2014, 05:37 PM
Broadway
, North Carolina
True that they all deplete oxygen. But a huge difference is that the latest small propane heaters have oxygen depletion sensors. They shut off before oxygen gets so low that CO levels become dangerous.
With these safety systems common now, I do not see how these small unvented propane heaters are a higher risk than any other heat source in our trailers. If we cannot trust ANSI and CSA approved safety circuits on these unvented propane heaters, should we trust the electronic safety circuits on our furnaces or water heaters that follow the same organizational standards?
Or for that matter how can we trust the CO detectors installed in our trailers which are also CSA compliant?
2006 Safari SE FB
Broadway, NC
08-12-2014, 09:11 PM
1972 31' Sovereign
Benton
, Arkansas
An advantage that a vented furnace has over their unvented brethren is that in order to asphyxiate the trailer occupants a vented furnace must in most every instance suffer a heat exchanger failure.
I know a person who was in a coma for weeks because of a portable propane heater he was using in a tent.
My sons are staying in my trailer tonight. Now they wont be in need of a heater tonight, but if they were,,,,, I wouldn't let them use an unvented heater, in fact, it wouldn't even be in the trailer.
