Old 01-26-2014, 03:33 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Polishing progress
Took advantage of the warm weekend in Ok, upper 50s yesterday , upper 60s today( high of 22 for next couple of days)! First cut of f9 on one side, two more cuts to go!!Click image for larger version
Name:	ImageUploadedByAirstream Forums1390775590.655472.jpg
Cochese is offline   Reply With Quote
Old 01-26-2014, 03:58 PM   #2
mtbguy's Avatar
Dunwoody , Georgia
Looks good!
mtbguy is offline   Reply With Quote
Old 01-26-2014, 05:39 PM   #3
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Looks great a lot of work there and more to go. Keep up the great work!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 01-26-2014, 06:31 PM   #4
Okiestreamer's Avatar
1999 25' Safari
Adair , Oklahoma
Looks great. I live in Adair and just finished stripping and polishing our in early Dec. I didn't do the mirror finish but it looks much better than it did with male pattern baldness.
Dave
Okiestreamer is offline   Reply With Quote
Old 01-26-2014, 07:09 PM   #5
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Thanks, I've been dealing with corrosion issues which take many passes w/ F9! Never had that issue w/ my globetrotter .
Old 01-26-2014, 09:03 PM   #6
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Tulum , Mexico
Send a message via AIM to albert Send a message via Yahoo to albert
What's does it take to get that mirror finish?
albert is offline   Reply With Quote
Old 01-27-2014, 05:49 AM   #7
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I'm using Nuvite f9 , then Nuvite g6,& finally Nuvite "S" w/ a cyclo polisher.
Old 01-27-2014, 08:11 PM   #8
1963 19' Globetrotter
Moline , Illinois
Warm weekend , whats that? We hit +1 today.
63air is offline   Reply With Quote
Old 01-28-2014, 10:57 AM   #9
1966 17' Caravel
Now you are going to be the polish guru!
Old 01-28-2014, 02:45 PM   #10
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I am far from a polishing Guru! Unfortunately this is not my first airstream to polish, this one is 7 feet longer! When I sold the Globetrotter I swore that I didn't want another polished Airstream,but with all of the work(and $$$) that has gone into it, I just cant help myself!! Im sure soon I will see a commercial soon about a name & prescription drug to "fix" this illness.
Old 01-28-2014, 04:07 PM   #11
1966 17' Caravel
And next would be the commercial for the law firm to help you sue them for the rare deformity caused my the medications side effects.
Cliff
Old 01-28-2014, 04:35 PM   #12
Chillbilly's Avatar
1987 32' Excella
Maryville , Tennessee
My Airstream is badly corroded. I've tried about every polish to get it looking better with no good results. What is recommended? I don't need the mirror finish, though it looks terrific, I just need more of an original finish. Is this possible?
Chillbilly
1987 Excella 32 Foot
"Campgrounds In And Around The Great Smoky Mountains National Park"
Chillbilly is offline   Reply With Quote
Old 01-28-2014, 06:07 PM   #13
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Mine has areas of corrosion as well. Short of replacing panels, all I can do is go over the affected areas many times w/ F9( Nuvite) to minimize the appearance of the pitting. As far as achieving an original satin look, I have no idea! I'll let someone else weigh in on that!
Old 01-29-2014, 07:13 PM   #14
Mixter's Avatar
1976 27' Overlander
Chillybilly- make sure the clearcoat is stripped... I stripped mine right off the bat when I got it. Now as I replace vents, windows, trim, etc. I'm polishing before I re-install the new vent, etc. However I JUST pulled the old AC for replacement and as I began to polish the opening and surrounding area, I was becoming frustrated that it was not cutting like previous areas. I finally realized that I didnt strip the clear there because the old AC was in the way. After stripping, it cut nicely with F9... many more steps with the finer grades, but happy it is cleaning up.
Mixter is offline   Reply With Quote
Interior Polishing Aktundra 1961 - 1963 Bambi 13 09-22-2013 11:46 PM
Finally polishing my 34' c_lewis77 Cleaning, Stripping & Polishing 106 08-25-2012 02:34 PM
Polishing our new Girl! bluemoontwo Cleaning, Stripping & Polishing 2 09-17-2011 07:03 AM
