Old 12-02-2012, 01:40 AM   #1
donabston's Avatar
2012 25' FB International
Baton Rouge , Louisiana
Plexiglass sliding cabinet doors jumping
My 2012 International 25 FB has the sliding plastic doors on the cabinet above the table at the rear of the trailer. Quite often after a drive at least one of the slides jumps the track and binds in place. Has anyone experienced this, and have they found a fix? Maybe some kind of glue-in piece to prevent the jump?
Thanks, Don
donabston is offline   Reply With Quote
Old 12-02-2012, 02:00 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Thanks, Don
My Interstate has sliding plastic doors on the cabinet over the driver's and front passenger's seats. Easiest fix for your problem is to drill one hole in the upper track and upper edge of the door, and insert a metal pin. Not only keeps the door from jumping its track, but keeps it from sliding until you're ready for it to slide. Pin should fit snugly, and use a short safety chain to keep it from getting lost if it should happen to work loose.
The pins you can buy in hardware stores for pinning sliding glass doors will work, and would already have the safety chain attached.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-02-2012, 04:51 AM   #3
Thanks, Don
Balancing the running gear helps, along with a soft ride. Heavy duty tow vehicles and over rated hitch bars, also cause the same issues
Old 12-02-2012, 07:04 AM   #4
2003 25' Safari
Riverside , California
I lost a sliding mirror door in the bathroom,and found a spring type device to put tension on the sliders on line.Unfortunately I can't find that site again to place the order.Any one else find such a device?
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 12-02-2012, 08:54 AM   #5
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
We had a similar problem with cabinet doors popping open. Turns out we had tires out of round and couldn't be balanced.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 12-02-2012, 09:21 AM   #6
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
Most of the sliding locker doors on our brand new International would slide open or jump tracks. We found that almost all of the leaf springs were bent or broken. We got the parts from Airstream and replaced them. Problem solved.
dkrug is offline   Reply With Quote
Old 12-03-2012, 08:41 PM   #7
donabston's Avatar
Thanks for the ideas. I checked, and sure enough the leaf springs in the tracks were not putting enough pressure on the panels in the closed position. I bent them out a little more, and they seem to work better. I'll see how this works, and then try new ones if necessary. I'll keep the option for putting pins in if nothing else works. Thanks again...Don
« Rivets | Top | Super glue? »
