Old 08-07-2017, 10:36 AM   #1
dznf0g's Avatar
Oswego , Illinois
Pine tar/pitch
Maybe this is old hat for those who live in piney territory, but I got a liberal dose of pine pitch dripped on the TV and AS while in upstate NY. After trying a variety of chemicals in my arsenal, I found Sparkle Glass cleaner was the best solution. While still a bit of a job, it was gentle on all paints/clear coats, glass ans Plexiglas. Let it soak a bit and rub with a very wet, Sparkle soaked cotton rag.
-Rich-
Old 08-07-2017, 01:34 PM   #2
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Simple Solution
We're deep in New England with loads of pine around including our yard. It's never a pretty sight when you discover that dropping on the beautiful clean finish of your TV or AS.
What we've used is a simple ingredient from the fridge. Never thought of it... in fact totally unexpected.
Mayonnaise
That's right, just dab some mayo on the offending drop, let it sit for a little bit and wipe it off. With heavier pine drips apply it again until it's fully removed. It even works on your skin. Amazing stuff...
Tom
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 08-07-2017, 01:57 PM   #3
dznf0g's Avatar
Oswego , Illinois
Mayonnaise
Tom
I'll try that. Although I have cleaned the TV and most of the AS, I am sure I will be finding new spots for some time. I assume it has to be mayo, not miracle whip?
-Rich-
Old 08-07-2017, 02:27 PM   #4
Boxite's Avatar
2008 22' Sport
WD-40 will remove almost all tar, pine, glue, etc., and is actually a GREAT cleaner for washing the car also! I buy it in gallon cans, pouring a cup or two into a 5-gal bucket, add water from the garden hose to turn it into a milky-emulsion.... rinse the car/airplane/etc off with a hose, use the emulsion instead of soapy water.... rinse again and dry with old towels.
It lubricates all the weatherseals, door/window hinges, leaves a just-waxed appearance and water beads-up if it rains as if it's been waxed. Straight WD 40 will remove road tar, wax, spilt paint, etc etc. (The mayonnaise has OIL in it as it's major ingredient and is why it will dissolve tar.)
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-07-2017, 02:33 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
WD-40 in the car wash bucket is similar to the old timers trick of a cup of kerosene.
I usually grab the WD if I only have a spot or two of pine sap to clean off of a vehicle. If it is a large amount, I use mineral spirits.
CRH is offline   Reply With Quote
Old 08-07-2017, 03:02 PM   #6
STREMN's Avatar
Yep just plain old mayo...
Interesting about the WD-40, learn something new everyday. I've always used it for the SS parts (rock guards, etc...), have to give it a go as an emulsion for a general wash.
Tom
Old 08-07-2017, 03:31 PM   #7
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
It says in my owners manual for my 67 to pour kerosene down the drains for winterizing. Another use for the stuff if you can get past the stink of it.
Dingo Girl is offline   Reply With Quote
Old 08-07-2017, 05:30 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Rubbing alcohol
2012 Dodge Durango Hemi/AWD
Old 08-07-2017, 06:05 PM   #9
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Wayne&Sam View Post
Rubbing alcohol
How does that do on plexiglass?
-Rich-
Old 08-07-2017, 07:43 PM   #10
Half a Rivet Short
Carlisle , Pennsylvania
Hi
WD-40 / Kerosene, mayo, ketchup, turpentine, and Windex all should be fine on Plexiglass. Since most Airstream's have Lexan on them that may not be the answer to the question you really wanted to ask . They are all ok on Lexan as well.
Old 08-07-2017, 09:06 PM   #11
dznf0g's Avatar
Oswego , Illinois
Hi
No they're not. Never use Windex on lexan. Been there done that. Instant fogging and dulling.
-Rich-
Old 08-08-2017, 12:42 PM   #12
Boxite's Avatar
2008 22' Sport
NEVER use Windex with Ammonia...on plastic. It's the Ammonia that kills Plexiglas/Lexan/etc. It also is why so many autos have crazed headlamp lenses. RTV (silicone adhesives) also smell like ammonia because that's how they cure. Using RTV near plastic can ruin some plastics. GE makes a type silicone adhesive specially for plastic/lexan/plexi... and it can be found in big box stores next to their selections of plastic window supplies.
The "cup of kero in a bucket" and "kero stinks" commentary brings me to explain a bit more about the WD-40 use...
My Dad bought a '57 Chrysler and Mom showed him her copy of "Hints from Heloise"... which recommended a cup of kero in a bucket of warm water for washing the car. Dad tried it and it works wonderful.
When I acquired a highly-polished aluminum airplane (a restored 1953 Cessna 170) I wanted to avoid re-polishing ...but I hated the smell of kerosene... so I used WD-40 as an experiment. It's now been 18 years of ownership of a 65-year-old airplane and I've never had to re-polish the airplane, and nary a smidgen of corrosion anywhere either.
Rambox
Old 08-08-2017, 01:31 PM   #13
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Nice plane and thanks for the tip on WD-40. I had a 182 that was painted in the ugly 76 yellow and brown scheme. Wife called it a new breed of bird, "yellow belly money sucker"
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-09-2017, 10:00 AM   #14
Boxite's Avatar
2008 22' Sport
Ha!
Thanks.
Here we were over Lake Okanagan, British Columbia, headed out to Nanaimo, Vancouver Island a couple years ago...
We've had it all over North America:
Rambox
Pitch and road tar Orson Cleaning, Stripping & Polishing 4 09-30-2011 09:09 PM
A pitch for the Airstream Park in Minnesota markdoane Airstream "In the News" 14 08-11-2009 04:39 PM
tar removal? lisa.bivens General Repair Forum 17 07-10-2008 03:37 PM
removing leak "fix" of PO (tar) obxairstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 05-17-2008 05:33 PM
high pitch whining noise.. safari25-05 Tow Vehicles 13 03-21-2008 08:39 PM
