Old 06-23-2012, 12:02 PM   #15
Goal15's Avatar
Dallas , Texas
Originally Posted by MrUKToad View Post
I managed to crush the metal connector, car side, doing a tight turn. My dealer suggested I do as the picture shows below, hooking the spring loaded cover through the hitch ball locking pin and keeping all the wires up out of the way. I appreciate not all setups are the same as this but it's worked well for us.
Thanks for the suggestion and the pic.
when i get a chance im going to go up to storage and see how much extra cable play i have and if i have enough i will probably just replace the plug on the cable just aft of the crimp.
JC says that the 7 pin connector cable that came with our AS is 12 feet long. there must be an extra six feet stuffed inside the a frame someplace because its not 12 feet from my bumper to the front of the trailer where the connector box is supposed to be.
Save that, will proably go with the temporary liquid rubber and electrical tape fix, then have the replacement done at some point.
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 08-07-2012, 07:36 PM   #16
2008 23' International CCD
Denver , Colorado
In our 2008 International I see the junction box deep behind the "L" sofa. How do I get the sofa out of the way? That looks like a crazy job in itself.
Jim and Marsha
"Tow'd Hall"
AIR #35886
JimmyT is offline   Reply With Quote
Old 08-07-2012, 08:20 PM   #17
Goal15's Avatar
Dallas , Texas
That's a good question.
I've gone with the tape and be watchful approach. may do the proper fix the next time it gets below a hundred million degrees here in Texas.
we went camping and i forgot to look and see if there is an access panel on the L lounge or if i have to be a skinny contortionist to get to the access panel.
Dana and Olga
2006 Safari 23
