Old 10-05-2012, 08:55 AM   #1
1962 22' Safari
lansing , West Virginia
Pimp my Pullbehind
I have owned my 73 Argosy for about 18 hours and I already want to style it out. I wonder what kind of bolt pattern do they have. Can I use chevy rims? I want to rdess it up with some aluminum mags.
profishwv is offline   Reply With Quote
Old 10-05-2012, 09:31 AM   #2
1974 Argosy 20
Kooskia , Idaho
I stole this from someone else's post here on the net.
15” X 6”
Zero Offset
Six Lug on 5.5” centers
4.25” Center Bore
2,600 pound minimum load carrying rating
Must be able to handle 65 psi inflation or greater.
Old 10-05-2012, 09:41 AM   #3
Pillow's Avatar
Warrenton , Virginia
Yes. I believe the normal 6 lug Chevy truck wheels work. BUT the stud length and width (smaller) might be an issue.
I run 8 lug Chevy steel wheels, but I cannot fit AL wheels due to the extra thickness. Also my studs are smaller and require 13/16" nut (standard RV size) instead of the normal 7/8". Not perfect, but it works.
There are specifically designed trailer AL wheels which should comply perfectly... But most lack the bling factor.
Trailer: 1948 Spartan Mansion 30'
Tow Rig: 2010 Cadillac Escalade ESV
Tow Rig: 1971 Chevy C-10 with 5.3 LS and T5 conversion
Other: 1979 Porsche 911 SC
Pillow is offline   Reply With Quote
Old 10-05-2012, 10:56 AM   #4
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
There is a great variety of nice looking 15 inch trailer wheels available.
Here is a sample.
15 inch Trailer Wheels Rims, Chrome, Aluminum, Steel, Galvanized, Painted, Custom Trailer Wheels
Ken
Old 10-07-2012, 11:42 AM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Make very sure you're good with the weight of your trailer and the load rating of the wheels.
The other issue you might want to keep in mind is that unless you just won the PowerBall, there will be many, many other things on the trailer which will require an investment.
You can trust me on that!
