I am amazed at the design too. It is really horrible. I am so amazed when I look at it. terrible. Did they loose a patient design to coleman? whats the deal. I am an rv dealer that has a personal airstream. I put a penguin 2 on the front because I like the exterior low profile look. I have a coleman mach on the rear. I had booth units already that is why they are mix matched. The coleman has superior airflow. I just installed the low flow trim kit for the penguin 2. It directs the majority of the air to the rear. I wanted the better designed kit, the second one you mentioned. dometic said it would on fit. What did you end up with?
