Old 01-03-2013, 01:41 PM   #1
1972 23' Safari
Neptune beach , Florida
Question Patching plastic sink help
I have a hole alittle bigger than a silver dollar in the plastic sink of my 71 25' land yacht rear bath sink.. How and what's best fix?Thx
Rmoran113 is offline   Reply With Quote
Old 01-03-2013, 02:15 PM   #2
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Do you have the piece that broke out? If you you might be able to epoxy it back in, and then paint the whole sink. You might also check with Inland RV to see if the have the replacement sink top. I saw one on there, but I'm not sure for what year..
Silverflames is offline   Reply With Quote
Old 01-03-2013, 02:30 PM   #3
1977 Argosy 24
Milltown , Wisconsin
Sand the area on the top side around the hole and bevel the edges of the hole. Put duct tape on the bottom to cover the hole and fill the hole with epoxy. When the epoxy is hard remove the duct tape and sand the bottom around the hole and the epoxy. Then spread some more epoxy on the underside where you just sanded. Then sand the top side of the bowl to blend the epoxy in with the rest of the sink, and paint.
ventport is offline   Reply With Quote
Old 01-03-2013, 02:44 PM   #4
1972 23' Safari
Thx
What kind of epoxy works best with plastic?
Old 01-03-2013, 02:44 PM   #5
1972 23' Safari
Thx ill try them.
Old 01-03-2013, 03:41 PM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I used West System Epoxy on several repairs on plastic parts in the bath of my 68. Figured if it was good enough for boat and composite airplane builders it would be fine in the AS. You can buy it at any marine supply store. I used fiberglass cloth and fixed the holes from the back side. After it dried, I mixes a little more epoxy with microballon filler and made a thick past to fill in the low spot in the front with a plastic using a plastic "bondo" applicator. After a day of drying I wet sanded the spots to blend and then painted with 2 part epoxy paint. Still looks great after 3 summers of use.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-03-2013, 04:38 PM   #7
1977 Argosy 24
Which number West System epoxy & hardener did you use?
Old 01-03-2013, 05:22 PM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I believe the sink and counter is ABS plastic. There are several threads on different formulas for patching. Most use ABS filings with some kind of binder. Personally I found nothing that worked 100%. After a few weeks cracks reappeared. I suspect that had something to do with different rates of expansion/ contraction with temperature changes. Is your sink and counter a single unit? Airstream calls it a lavarette. I call it a sink.
Old 01-03-2013, 05:46 PM   #9
Member Slide Out Society
2004 28' Safari S/O
Zavalla , Texas Airstream Harbor
I highly recommend Marine Tex... available at most boat dealers parts departments. I have repaired fuel tanks, boat hulls, washing machines and electric fuel pump... never had a leak again. It is very easy to work with, like bondo..can be sanded, painted, etc and is flexible so that it moves with the sink if it flexes at all...hope this helps
Rockwell
Rockwell is offline   Reply With Quote
Old 01-03-2013, 05:51 PM   #10
1984 31' Sovereign
1978 Argosy 24
Zavalla , Texas
68 TWIND's fix is the same way I worked a number of problems on my 78 Argosy redo. I use West 206 Hardner and 105 Resin. The 206 goes off a little slower. Cheerz
Orlop is offline   Reply With Quote
Old 01-03-2013, 07:21 PM   #11
1969 29' Ambassador
Another option could be to buy a oval stainless steel sink, cut out the abs sink, and drop in the stainless steel sink. It's not original, but it beats a holy sink...
Old 01-03-2013, 07:32 PM   #12
1972 23' Safari
I like this idea..ill have to check to see it I can find correct size.
