Old 12-29-2014, 11:43 AM   #1
Sioux Falls , South Dakota
Parts
How hard is it to get parts for 20-year-old coaches? Other than body, any proprietary parts?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 12-29-2014, 12:23 PM   #2
1981 31' Excella II
New Market , Alabama
What sort of parts are you talking about? Most of the stuff as far as appliances are standard RV stuff. Some structural components are available from the factory.
Perry
Old 12-29-2014, 12:53 PM   #3
2000 30' Excella
Toledo , Ohio
If it's for Airstream not a problem
woodfox45 is offline   Reply With Quote
Old 01-01-2015, 07:26 AM   #4
Thanks. I saw a coach advertised that sounds like it might fit us, but it has been parked for 15 years in Florida. I suspect that replacing axles and brakes will be necessary. I wondered how difficult it would be to get them.
TAC SD-6
AIR 54240
Old 01-01-2015, 07:49 AM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings David!
Axles and basic running gear parts are readily available -- even for 50+ year old Airstreams -- Hydo-Vac disk brakes from the 1970s may be one exception.
Kevin
Kevin D. Allen
AIR #827
Old 01-01-2015, 07:49 AM   #6
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
We've drop shipped complete axle assemblies all over North America & beyond, plus there are other suppliers out there. Be very wary of an Airstream that has been parked in Florida for that amount of time. Depending on where in the State it has been sitting, there may be serious chassis rust issues. As the bellypan contains the chassis & insulation, it tends to retain moisture & humidity causing rust.
Good luck with your search.
Colin
Colin H is offline   Reply With Quote
Old 01-01-2015, 08:02 AM   #7
Thanks, Colin. The location was a big red flag for me, and we're not ready to buy now anyway, but that one made a good example.
What has prompted my reappearance here is finding out that Foretravel used a proprietary shaft in an otherwise standard hydraulic pump, and that has left us parked for two weeks. If it hadn't been for a mechanic friend we would have had to wait until March (!) for a replacement. I wondered if Airstream does something similar.
TAC SD-6
AIR 54240
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 04:39 PM
Parts is Parts!!! TRAPEZE Airstream Motorhome Forums 13 09-03-2002 11:48 AM
Antenna parts Dbraw Our Community 2 06-22-2002 01:21 PM
Source for brake parts? 74Tradewind Brakes & Brake Controllers 9 06-11-2002 04:26 PM
'66 Safari - step and window guard parts? Gordon 1966 - 1968 Safari 1 04-20-2002 11:16 AM
