Old 03-07-2014, 08:01 PM   #1
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Part for Zip Dee Awning
The release on the awning came off when I went to roll up the awning. I was able to use pliers (actually side cutters) to pull the spring-loaded rod to release the catch. I assume that these catch assemblies can be removed and replaced - am I correct in my assumption? Do I have to get them directly from Zip Dee (I'm camped in AZ now), or is this something I can get from an AS dealer? What is involved in replacing these catches?
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 03-07-2014, 08:10 PM   #2
Central , Mississippi
The entire assembly just unscrews from the side of the square tube. Dunno if a dealer would have it or not, zip dee would be able to get you one.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-07-2014, 08:15 PM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Here is a parts breakdown I found on Zip Dee's website
http://awningsbyzipdee.com/media/19b...08ffffd523.pdf
Based on this, I see that it is part number 290002 (Snap Stud Assembly). What I don't know is how is this attached to the square tubing - is it screwed into an already tapped hole?
VE3JDZ
AIR 12148
Old 03-07-2014, 08:17 PM   #4
Originally Posted by blkmagikca View Post
... - is it screwed into an already tapped hole?
Yup!
Old 03-07-2014, 08:22 PM   #5
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Good! Now to find out where I can get them. I'm an hour west of Tucson, so maybe Lazydays would have them. I'll have to phone Zip Dee tomorrow morning.
VE3JDZ
AIR 12148
Old 03-07-2014, 08:24 PM   #6
Ottawa , ON
If you go to their site, there's an 800 number for them. Their phone parts order service is superb, and they will make sure you get the exact part you need.
Old 03-14-2014, 11:36 AM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Part arrived from Zip Dee and it was easily replaced. I noticed that the original "knob" was hexagonal, while the new one is slightly wider and thicker and is knurled. BTW, the part is about $10. The ratchet ones are $14. I bought two of each, so I have spares (the awnings are original 1987).
VE3JDZ
AIR 12148
Old 03-14-2014, 02:13 PM   #8
1981 31' Excella II
New Market , Alabama
I don't think that lock on that pull thingy have ever worked on mine. I just hold it out with one hand and push with the other. I do see a crack in yours where the hold back pin should be.
Perry
Old 03-14-2014, 07:57 PM   #9
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Smile
Perry
Perry, there are two different latches. One just has the round pin that fits into the hole, called a snap-stud assembly (p/n 290002) which costs about $10 and the other is called a ratchet stud assembly (p/n 290001) which costs about $14. The ratchet stud assembly has the pin in it to align the ratchet, which you feel when you snug up the rafter arm bar. The knobs in the photo that have the crack in them are the snap stud assembly.
Everything is working fine now - we do need the awning these days, as it is warm and sunny here in the Sonora Dessert in Arizona
VE3JDZ
AIR 12148
Zip Dee awning 69Olander 1969 Overlander 4 02-14-2012 03:11 PM
Replacing Zip Dee awning canvas webspinner Awnings 23 02-06-2012 06:03 PM
carefree awning fabric width johnhh Awnings 0 07-30-2011 09:16 AM
Zip Dee using Silicone?????? SailAS Awnings 19 06-12-2011 12:39 PM
