Old 06-21-2019, 12:49 AM   #1
Alumaddict
IslandLife's Avatar
1970 31' Sovereign
Ladysmith , British Columbia
Pan corrosion?
Iím sure that someone has come across this but I couldnít find any threads on the topic. Itís between the crossmembers of the frame and not in direct contact with the frame in the area if corrosion. It is just in front of where the fresh water tank was. Iíd like to figure out what happened to prevent it from happening again. Thanks in advance!
Ken
ID:	343990   Click image for larger version
IslandLife is offline   Reply With Quote
Old 06-21-2019, 05:06 AM   #2
Kevin245's Avatar
Appears to be galvanic corrosion (GC). It can be minimized by coating the materials to prevent direct contact. There is always the potential of GC when dealing with dissimilar metals.
Eleanor Roosevelt
Old 06-21-2019, 09:06 AM   #3
Alumaddict
IslandLife's Avatar
1970 31' Sovereign
Thanks Kevin,
From the look of the edges, it does appear to be galvanic corrosion of some sort. Though the area of corrosion was not contacting the metal frame. It may have been the copper propane lines (no longer there). From the little bit that I've read, steel in contact with aluminum isn't nearly as corrosive as copper is to aluminum. This trailer also spent some time near the ocean in a high humidity/salty environment. So that would have likely sped up the process.
I'll read up more on galvanic corrosion. I've previously had a welded aluminum boat, and sacrificial zinc anodes are used extensively to protect the aluminum.
Ken
Old 06-21-2019, 11:23 AM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Where in relation to that is the propane lines run outside the pan?
I'd be curious to see what the outside vs. interior patterns are.
I've seen aluminum outlive the iron it was sistered in next to - yes the Aluminum is weakened and white with oxide but the iron went to lace with missing sections.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 06-21-2019, 05:35 PM   #5
Alumaddict
IslandLife's Avatar
1970 31' Sovereign
Definitely in the vicinity of the copper propane line. And seeing how it was only held by a string for who knows how long, I suspect that it was contacting the pan on a regular basis. No rubber mounting brackets at all on the forward half.
Old 06-21-2019, 06:16 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
My guess is the aluminum was exposed to road salt for years without being washed.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 06-21-2019, 06:38 PM   #7
dznf0g's Avatar
Oswego , Illinois
Or....our airstreams never have assembly scraps of schtuff just sitting around...everywhere, right. Steel scraps+ aluminum+water +time=galvanic degradation. Perhaps.
-Rich-
Old 06-22-2019, 01:05 AM   #8
Alumaddict
IslandLife's Avatar
1970 31' Sovereign
I did manage to get under it completely today and found the pan was overall in decent shape. At least better than I had expected. I wasnít able to get under it completely before I bought it, and I was expecting it to be worse. Other than the main cluster of corrosion, there were only a few other spots. So Iíll patch it and seal it up.
This trailer will spend at least the next couple of years parked on my property as a cabin. I just want to make sure that the mice and such donít have easy access to the belly of the trailer.
Belly pan corrosion 02safari25 Belly Pans & Banana Wraps 11 10-12-2019 08:01 AM
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Pan or no pan bigal1437 Furnaces, Heaters, Fireplaces & Air Conditioning 9 08-20-2017 08:54 AM
Should I use Corrosion X on brand new trailer to prevent corrosion ILOVESALLY General Repair Forum 31 06-25-2016 12:06 PM
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
