12-02-2018, 05:46 PM
Fulshear
Pairing back up camera
Having an issue pairing backup camera on 2019 Classic 33 with the monitor. Camera was factory installed—pairing is initiated on monitor without success. Any thoughts.
12-02-2018, 06:10 PM
2019 22' Sport
Turn on your headlights that worked for me
12-02-2018, 06:11 PM
2014 25' Flying Cloud
Cuddebackville
, New York
Are your parking lights on? The camera gets its power from the parking light circuit.
2019 Ford Expedition Platinum
12-02-2018, 07:28 PM
2017 28' International
Jim Falls
, Wisconsin
Ditto. For mine to pair I have to have my lights on. It will work. Nice feature to have while traveling.
12-03-2018, 10:36 AM
The Silver TARDIS
2018 30' Classic
Hillsboro
, TX
You need to have your running lights on.
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
12-03-2018, 11:10 AM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
If having your running lights ON are still a no go. Move the display closer for the initial pairing. I've noticed, some environments have a lot of interference.
12-03-2018, 03:57 PM
2017 30' International
Cumming
, Georgia
On mine it’s critical that I first plug in the monitor, once it is on, then I turn on my parking lights, I have to go in that order or it won’t connect. Good luck!
12-03-2018, 05:01 PM
ObviouslyKnot
KAILUA
, HI
On my old '17 Classic, I turn on Monitor, Press the Pair button, then turn on running lights, holding the Pair button until the camera paints to the Monitor. Just happens to be the procedure from the manual. Gets the best pair signal strength that way. At delivery, the guy said just plug it in and turn on, it will work automatically. It does, most times, but with a weaker signal.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
12-03-2018, 06:20 PM
2018 30' Flying Cloud
Elgin
In my situation. I need to turn the head lamps on. parking lights do not do it.
Caz.
12-04-2018, 05:36 AM
Fulshear
Pairing advice thanks
Thanks to all. Took your advice and camera now paired to monitor.
12-04-2018, 06:37 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
The camera on the AS is not on while underway?
Seems like a waste of a good camera. 🥴
12-04-2018, 07:18 AM
ObviouslyKnot
KAILUA
, HI
Mine is on underway, I don't drive without it; just have to keep the lights on.
12-04-2018, 04:58 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Same here...but lights don't have to be on.👍
12-04-2018, 05:08 PM
2018 27' International
carbondale
Lights can not be on auto. Has to on direct lights. Took awhile to figure that out.
12-04-2018, 05:19 PM
2015 28' Flying Cloud
Waxahachie
All depends on how the camera has been wired. Most tap into the clearance lights on the Airstream. If in fact done in that manner, clearance/running lists must be on therefore lights on TV have to be on. Some have wired in different manners allowing it to operate without having TV lights on.
